Clutch not Disengaging.....master cylinder pulsating
ok....clutch has been having problems disengaging over the last couple of days....today of all days....the clutch stopped disengaging. I felt and heard a loud pulsating sound coming from the clutch pedal. Right now cant get the transmission to go into any gears.....would this be a sign of slave cylinder failure? already spent a few hrs bleeding the clutch.....no improvement at all. Is it time to drop the transmisson and install a new slave cylinder? ....any ideas or thoughts? thx for your help.
I was thinking it could be the clutch gone bad...maybe the pressure plate broke...clutch seems to be always engaged not disengaging at all. Guess I should look at getting a new clutch too....Thanks for the input .
ive been in a similar situation, normal driving i put it in 5th and began to let off the clutch, i hear a loud *** bang the clutch pedal just became free as a bird all kinds of grinding sounds n ****...pull off the road shut it down, and i couldnt push the clutch pedal in AT ALL, turns out the throwout bearing shattered, so might wanna look into that....hope that helps
yep...I know its going to cost me some coin. Luckily Im doing all the work myself that will save me some money....problem is I need my car running by tuesday morning the clock is ticking....tick..tick....its been so freakn hot and humid today...thank you hurricane alex!!! Thanks for the input.
i got the stage 2 monster 1260 and had it installed for 435 at tick performance but i got the hole package, Tick Master Cylinder slave cylinder throw out bearing pilot bearing and clutch kit i also upgraded to a different flywheel, Check out there packages at tickshift.com
