Vig 2800...
Vig 2800...
is more like a 3200 right? I bought the car with the TC, and can hardly tell it is there if at all. I haven't drove the car 300-350 miles, haven't really put it through it's paces, and haven't been in another A4 LS1. M6 LS1 SS-Yes. A4 LT1-Yes (previous car), so I really don't know what to look for or expect! I have searched and found out it is like stock...so why even get it then? I really know nothing about TC's as one can tell!
it is actually a 3200, yes. While being a mild converter by most people's standards, it is still a serious improvement over stock and offers excellent drivability.
With any good converter, gears don't give good gains. The converter is already doing most of the job that going with extra gearing advantage does. I wouldn't expect more than a 1-1.5 tenths in the 1/4 by going to 3.73s from 3.23s. If you have 2.73s and go to the track alot, a gear change makes alot more sense.
Honestly, I'd stay with the stock gears if you're keeping the stock rearend. If you're going to change gears because you're a serious track hound (that would mean you're at least running mid 11s) then I'd spend the dough on a 12-bolt rearend.
To reassure you of that. Consider that with 3.23 gears, a TCI SSF3500 stall, an almost stock weight car, and bolt-ons, I went 11.8s with 1.61 60fts. Now, the same car is running 11.2s with 1.55 60fts after heads/cam and an SS4000 stall converter. Same old 3.23 gears. I love 'em. A great street/strip gear, IMO.
i found the 3.42 gears works great if you do a bit of city driving. The TCI SSF3500 isn't THAT bad. i was expecting worse. but it cruises around 2200-2400rpm when its "loose". It's very drive-able i was expecting alot worse how people say 'verters are loose, but you gotta give some to get some, and the 2.73 -> 3.42 conversion i think helped out alot. Especially since i city drive so much.
