Tuning after new trans and converter?
Old 07-08-2010, 02:48 AM
Chubbz155's Avatar
Default Tuning after new trans and converter?
i just installed a built 4L60Ewith a shift kit and a 3200 stall. I was wondering if I can drive it with out tuning it or if it will mess up my new trans? Thanks in advance!
Old 07-08-2010, 08:22 AM
Internet Mechanic
BlackScreaminMachine's Avatar
If you have never had the PCM modified. It would be a good time to get the Torque Management Tuned Down if not deleted. I see you have 3.73's if that has not been done yet to adjust for the Speedo, it would be a good time as well.
Old 07-08-2010, 11:10 AM
Chubbz155's Avatar
I have had the speedo adjusted and the torque management turned down to 50% before. Is it safe to drive right now with out a tune?
Old 07-08-2010, 11:15 AM
TXZ28LS1's Avatar
you will need to get codes P0751, P0757 deleted..your car will drive horrible without deleting these codes.
Old 07-08-2010, 12:26 PM
race_chevy_37's Avatar
yea u will be fine to drive ur car i put the same tranny in my car and dint get a tune and it runs perfect
Old 07-08-2010, 01:20 PM
Kevin01Z28's Avatar
You probably will need these codes deleted. P0757 came on the first time I drove my car after the converter install causing it to go into limp mode, no fun..
Driving with the stock part throttle shift points will cause extra slip, which means more heat in your trans. If it does go into limp mode, stop and turn the car off for a minute or two. Then you should be ok.
Personally I would have it tuned ASAP. To much money at stake. I have a mail order tune now but will be getting a dyno tune as soon as I get some time off work and my lockup issue resolved.
Old 07-09-2010, 01:22 AM
Chubbz155's Avatar
Will these codes come up as a check engine light or are they just stored in the ECU?
Old 07-09-2010, 12:50 PM
Kevin01Z28's Avatar
Both of those codes will cause your trans to go into limp mode. Yes your light will illuminate.
Old 07-09-2010, 02:37 PM
Chubbz155's Avatar
Thanks Kevin! My SES light is not on, so i am doing good i guess!
Thanks everybody!
