im confused?!?! somthing with gas
well today i drove the car around and i ran the gas down to a little bit above the quarter mark and put in 10$ and then i drove for about 20ish miles and the gage read half and then the car started acting like it had no gas it keep dieing out on me so i put another 6$ in it and the gage read a little over half and it took me all the way back home witch was about a 45 min. ride so does anyone have any clue?????
i checked the fuel pressure already it was good but that was just from like a start up and drive for like 10 to 20 mins. this only keeps happening when i drive the car for about est. 1 hour to 2 hours longest i have drove it was today for about 2 hours be for it started to do that and it happened last time i was driving est. 1 hour so?
And it'll continue doing it until you shut it off and let it cool down? I'd Drive it with a fuel pressure gauge hooked up and tapped to the windshield then see if the fuel pressure drops off when it starts to do it. If it doesnt Look in to you injectors if it runs like **** while ideling see if you have a bad injector.
Check these things
Your fuel injectors might need a good cleaning, check how dirty your MAF is and try cleaning that out with some CRC MAF cleaner (that can interfere with drive-ability) and worse case scenario your fuel pump might be going bad.
A year ago my car did something similar. I replaced plugs, wires, cleaned my MAF, checked my fuel pump when I turned my car on to see if it was buzzing & so on. After that I haven't had that problem anymore.
Also, you might have a vacuum leak so check all of your hoses & lines to see if there is a hole or if any of them broke of snapped off by accident. I know you have a LT1 and I have the TPI engine but these 2 engines are very similar so hopefully my advice might help.
yes when this problem is happening it will continue to keep shutting of and if u read the begining of this this i aslo state what else is did like the part when i put more gas into it ect.. and then it drove fine ect.... so im gunna check fuel pump and clean injectors
