Problem!
Problem!
i have a 98 z28 i just changed the spark plugs and wires like a month ago but my car has been bogging down everytime i step on the gas. but when i let off the gas the car kind of jumps. does anyone know what might be wrong?
just a filter slp lid and exhaust. no codes are showing up. like its really bad when the car is cold but when it warms up its not as bad. and its bogged before but not like this
What gap did you use?
Might have broken a spark plug when putting it in. The ceramic part.
Go ahead and clean the MAF, as it is in play during cold start up and warm up, then it comes back into play only when you go WOT. After you're warmed up to operating temp, the MAF remains OFF during normal driving.
none of the wires are touching.
i used a .060 gap
and as for breaking the spark plug i checked everyone before i put it in.
and i just cleaned the maf like last week but ill do it again. i guess the MAF is bad because when i go WOT it doesnt do to good.
i dont know what the heck is wrong with it.
i used a .060 gap
i used a .060 gap
i used a .060 gap
Also, if its bogging when you hit the gas you could have a leaky injector too, which floods that cylinder when you hit the gas.
Spark plugs get broken alot of times while putting them in with the socket. And a broken spark plug can cause whats happening. I know it a big job to take them all out to check the ceramic part, just saying.....
yeah i just cleaned the maf and it really didnt do anything.
but i saw some smoke coming from somewhere under the headers any idea of what that might be? oh and is there a write up on how to clean the injectors or check them?
Have you checked your plugs yet? Check for spark at each plug? Fuel pressure? If an injector was bad enough to make the car run that bad it seems like the O2 would pick up on it and throw a code.
i found out what it was. i left the maf unpluged when i changed the water pump and it ran fine. so the maf is bad im guessing? does any one know whats a good maf to purchase im thinkning about the slp one.
