how to add 2 quarts to oil volume
You can run a dual filter set up. Perma-cool has one and Hamburger has a better one. I like the Hamburger version because it runs from the first to the second filter, not both at the same time like others. Better filtering IMO.
thanks for that info. I'll look into it.
thanks, I'll look for both units online.
another question is, I can just run an oil cooler and keep the filter in the current location right? I read it adds about 2 quarts which is exactly what I need and will also cool the oil which is another bonus.
just want to make sure Im not missing anything here.
You can plumb the factory oil cooler with the stock pan. There should be a block off plate on it now unless it was equipped before.
The fittings might get to close together to put them in, but you can mock up and decide if you need to go smaller. Have to see if the bigger will work, I think -8 would be fine.
Why do you want to add two quarts of oil. If your not starving it with the five quart setup I would leave it. As long as your not throwing it into the twisties five should be fine I think.
