coolant bleeder
I think I did something wrong today, when I fill the coolant, I never touch the bleeder. anyway after 10 min idle some coolant start boiling and steam coming out, it over flow a bit, then it back down, I add little more coolant, and after 10 more min THE COOLANT WAS SPILL HIGH EVERY WHERE ON MY ENGINE BAY , I turn off the car right away, then add coolant, I drove for a bit, temperture is normal, car run good. I let it sit for 3 hours, and went out check for coolant again, it full on the radiator cap. Should I keep take the cap off next couple day to check for coolant ?
no just open the bleeder screw, the one close to the radiator not the one near the water pump neck. What i do is run the car to operation temp and cut if off then open the screw for like a couple of min then close it back
If you did not open the bleeders while filling it, you certainly have lots of air in the system. Perhaps you have gotten most of it out, now. Do what I8ASaleen said and you can check the coolant level for a couple of days like you said.
BTW, are you in America? That's some pretty sketchy english.
