intake gasket ???
intake gasket ???
been having symptoms of a vaccum leak since a head swap no power popping through intake exaust sounds horrible raspy and crackly ,I changed the intake gaskets 3 times 3rd time using thicker gaskets but everytime I pull the intake there is oil between the gasket where the intake meets the head at the bottom , I have good clearance between the block an intake so hows oil gettin there so fast ???
pulled one of the heads today after hunting down this problem 4 a month now and noticed one of the exaust valves you could look through the exaust port and see light around the valve , so I poured water in the port and it leaks around it would this cause it to run like ****
no compression and sucking hot air back in when the intake valve is open well that cant be good
is that valve screwed up? spring ok? is it evenly showing light or just part of the way around was there any work done to the head? maybe try pulling the spring off and re install it could be easy as that
dont burn it... I accept donations lol
