Torquer V2 cam only results
Today I got to do some bracket racing at the local 1/8 mile. If only i knew it was going to be so dang hot I wouldn't have went haha. But either way here are my results
4100ft DA fist pass
60ft 1.73
330ft 5.0312
594ft 7.25
1/8ET 7.761
1/8mph 90.55
4170 DA second pass
60ft 1.7272
330ft 5.0239
594ft 7.2522
1/8ET 7.7522
1/8mph 90.32
i made a couple more passes and either spun or had to hit the brakes to not break out so here was my final pass of the day
4581 DA hot....as.....*****
60ft 1.74
330ft 5.0528
594ft 7.2890
1/8ET 7.7858
1/8mph 90.58
all in all a good time but the 94 degrees and 90% humidity with a 105 heat index killed the day. its full bolt-ons with a ss3600, 255 mt, skinnies.
I have 373 gears ready to go in now and if that doesn't make it 60ft better its getting a bigger stall. Let me know what you think and if anyone could tell me what you think it would run corrected it would be appreciated.
4100ft DA fist pass
60ft 1.73
330ft 5.0312
594ft 7.25
1/8ET 7.761
1/8mph 90.55
4170 DA second pass
60ft 1.7272
330ft 5.0239
594ft 7.2522
1/8ET 7.7522
1/8mph 90.32
60ft 1.74
330ft 5.0528
594ft 7.2890
1/8ET 7.7858
1/8mph 90.58
its around 3500 im guessing maby lighter since i was using the skinnies, its a cloth, manual seat car with a hardtop so its pretty light, My car just leaves soft for some reason. it looks like a 2.0 60ft if you watch it leave. i used to have a 4000 in it at one time but the lockup clutch was toast, but that converter would hit hard. spinning to a 1.64 with boltons which makes me want to go back to one. if i can get into the 1.5s ill be good to go.
i didn't calculate the da, my friends dad did and he bracket races every weekend so im pretty sure it correct. he also said the barometer was a 1.100 or 1.070 or something like that. if anyone can enlighten me on what that means please do. lol
Damn dude....4100da!! Man thats great times for such a high da. Try this website to compare but like the other guy said you have a mid 11 sec. car in good air. When I ran 11.60s my eigth mile time was 7.38-7.40@92....and that was in the winter! You will be shocked at how much difference neg. da can make. By the way I was thinking about that cam, how do you like it?
www.dragtimes.com/
www.dragtimes.com/
i really like the cam. has a noticeable lope to it but still has great drivability. it made 380hp and 370ft so i was pretty happy. i just need to got the 60ft down and ill be happy
did u ever get it on the dyno? im curious to see if im on par power wise also. a couple local people were saying my numbers were kinda low at 380hp and 370tq but idk.... im just ready for some cooler air to see what she does.
http://www.youtube.com/watch?v=slv0Q...layer_embedded
heres the video of it the day it got tuned. excuse the excitement at the end. lol
i have the stock 10bolt with 3:23s. i recently went to the track with better weather and stock rims and went 7.57 at 92mph with a 1.66 60ft. ready to get the 373s befor it gets too cold
thankyou. i made it to the quarter finals after buying back in. i broke out.... lol. im still a newb at it. the night i ran 7.57 at 92 i ran 2 other passes within. .002. its pretty consistant i would say. its just a pooch out of the hole though...1.66 is all she had in her.haha
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
I'd rather have an easier leaving car that runs a little more mph to judge the stripe versus a hard-hitting ride that could be subject to spinning. Either way, congrats the 1/4-final finish!
Derek
Derek
the car does launch really soft which really explains why the stock rear has lasted 100+passes.lol. after these gears im going to start saving for a transmission because the stock one will fail eventually. many remove the front swaybar and un-needed stuf here or there. i really want.to get the car mid 11s cam only
