Head and Cam with 100k on the block?
Old 07-26-2010, 12:29 AM
Brian'sCharlotte(TA)'s Avatar
Default Head and Cam with 100k on the block?
Would an aggressive head/cam set up (say MS4 and PRC215s) destroy a stock bottom end with about 100K? Anyone have any success running larger similar set ups on stock bottom ends with around the same mileage?
Old 07-26-2010, 12:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
well, you are going to be replacing a lot of moving parts up top so it should be safer there. I would say no. You should be fine. Just know that you might want to replace the rod bolts. Only thing that could destroy it really fast is an issue with PTV. Thats a tight combo, and TSP will set it up properly valve wise if you are getting the heads through them.
Old 07-26-2010, 01:54 AM
yeah, that was the plan. I'm just beginning to think that the motor wouldn't handle all of that with a tired bottom end. But I had planned to replace it after a while anyway... I just need it to last a little while though
Old 07-26-2010, 02:57 AM
00MaroonZ28's Avatar
You'll be fine. I had 116k miles on mine when I did my build. Just replace parts that wear.
Old 07-26-2010, 03:02 AM
IWGF's Avatar
I did H/C/I/N2O at 100k miles. You'll be fine.
Old 07-26-2010, 03:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
and just to add to what they are saying I did 244/248 cam at 92k and to my knowledge its still in the car...to whoever owns it.
Old 07-26-2010, 10:29 AM
Mike Morris's Avatar
As long as your motor is healthy you are ok...
Old 07-26-2010, 11:14 AM
twitchtwice's Avatar
yeah just make sure you replace all the gaskets on the parts that you are removing. and make sure to get at least a stock ls6 oil pump along with the new o-ring, as well as an ls2 timing chain. other then that you should be set.
Old 07-26-2010, 06:50 PM
99T/AMAN's Avatar
I just got done doing my h/c setup at 88k and still had the cross hatching marks on the cylinder walls. I replaced rod bolts also so i could spin it as high as i want
Old 07-26-2010, 09:24 PM
The_Rizzle's Avatar
Ha - I've got you all beat!
438,000 Km 1999 5.3
cam, rod bolts, bowl blend, head milling (.050) 918's, victor jr, 7500 rpm limit, and went off road racing it! Held together just fine. thing still has 45 lbs hot oil pressure, same as when we started!
Just do a compression test before to make sure everything is good to start. And check a rod bearing or two when you do the rod bolts, but I can't see anything being wrong unless you have bad oil pressure.
Old 07-26-2010, 10:54 PM
98RedRocket's Avatar
mine has over 200K and im about to cam n stall the old biotch!
Old 07-26-2010, 10:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
438,000 Km 1999 5.3
Its nothing spectacular when a truck does it! Still that is a lot of miles for a modified motor.
Old 07-26-2010, 11:35 PM
The_Rizzle's Avatar
It was pulled becauce of low comp in cyl 7, dry, so out of the tow vehicle it came.
The friend who I helped build it, wanted to see how cheap we could build some hp. The engine had great oil pressure, and no piston slap on startup. We pulled the heads and dropped the pan, the rods we checked had very good bearings, same as the mains, and the only ridge at the top of the cyl's was a little bit of slightly oily carbon (I've yet to see a decent km'd truck intake that isn't covered in oil inside) and the two pistons we pulled had rings that rotated freely, without having worn out ring grooves. If it wasn't for him having the truck from his work, where he bought it from 3 years ago, I wouldn't have believed it was a high km engine.
Also, the company does highway maint. up to 2 hours away, so I'm sure LOTS of the km's were highway, and not abused like a sports car. I wouldn't blindly do what we did to every ls engine that can get to that mileage, especially if it was showing any signs of age (using oil/bad oil pressure/knock) but this one checked out ok.
