got the ss spoiler put on now i have a problem
Ok guys so I finally got my ss spoiler painted and put on, but now i have the abs inop light on and cruise doesnt work. I know i saw a thread a long time ago on how to fix this but i cant find it. Can anyone point me in the right direction to fix the problem. thanks.
I've had the same issue for years. I just ignored it until now. Based on the diagram, how would you fix this problem? Are you just wiring in a relay? Who else has done this successfully?
You can get the relay from any auto parts store. IIRC I used the same realy that is used for the A/C pop off your fuse cover under the hood and you'll see some relays. Get one the same as those.
The Pam OS looking for resistant from two light bulbs on the stock wing. When it does not see the right resistance, it throws a code. The leds in the ss wing don't provide resistance, they appear as an open and that is why you get the light.
You basically have to fool the pcm with a relay or some bulbs.
does anyone have a pic of where they put their relay? will it fit under the plastic trim on the hatch? thanks again....not very good with wiring or fires for that matter.
Yes, it will fit under the hatch. Sorry I don't have any pics though. I used double sided tape to hold the relay to the underside of the hatch. It's very easy to do, Once you get started you'll see what I mean. If you have any troubles let us know.
I believe so yes, even though the abs will be deleted you might have problems with the cruise control. Don't qoute me on this it's been years since I did it. If you do have problems it takes less than 20mins to wire in the relay start to finish.
thanks for the info guys, as for the question above i believe this is just on cars that didnt come from the factory with the ss spoiler, mine is a 94z28 and i just wanted the look of the ss spoiler
airfix, did you use some connectors to hold the wires to the relay posts? bascially i'm just wiring in the relay to the negative and positive wires just before the led right?
Then you have nothing to worry about. It's possible there might have been a change in factory circuitry, but the fix is for when there actually are troubles when changing to the LED spoiler.
I used 2 female spade connectors with the plastic covering around the connector part. For the unused posts on the relays I put a bit of shrink tube on them, I don't think you need to but I did just because.
