LT1 aftermarket power steering pulley or cover?
Old 07-27-2010, 10:04 AM
onefastbird95's Avatar
Default LT1 aftermarket power steering pulley or cover?
I am looking for an aftermarket LT1 (95 formula) power steering pulley or even just a cover for the stock pulley. I basically want it for dress up purposes but can't seem to find anything. I heard a company turn one made one and I called them and they said they no longer produce it. I also called MARCH and they said they didn't sell one either....
Any suggestions or something I might be overlooking? thanks guys
Old 07-27-2010, 10:23 AM
Village Troll
SS RRR's Avatar
Did you check any of the LS1Tech sponsors?
Old 07-27-2010, 10:53 AM
Low N Slow's Avatar
Speed Inc.
Old 07-27-2010, 11:46 AM
RamAir95TA's Avatar
Speed Inc. sells one, but I hope you like skulls.
Old 07-27-2010, 02:04 PM
LS1 SPEED's Avatar
or 5 spoke
http://www.speedinc.com/cont.cfm?cid=C0001030
Old 07-27-2010, 02:13 PM
RamAir95TA's Avatar
Larry - thanks for adding a non-skulled pulley! I know it didn't meet alot of people's tastes. Good stuff!
Old 07-27-2010, 02:15 PM
LS1 SPEED's Avatar
Skull is for a few, but I the 5 spoke design done to fit most people wants
I need to get one on my car.
Old 07-27-2010, 02:17 PM
AChotrod's Avatar
I need to get one of the 5spoke designs sooner or later. Wish my car was drivable when you hit me up about them.
Old 07-27-2010, 03:58 PM
Thanks for the heads up...
Has anyone installed this pulley or another aftermarket pulley? Just wondering if the stock pulley can be taken off and this one inserted while the power steering pump is still on the car? I thought I saw something where you need a special tool to pop the factory pulley off?
Any advice or write ups on this?
I appollogize if this info is common knowledge, but I havn't had time to do a whole lot of research other than making a few calls and reading about the turn one pulley that is no longer available.
Old 07-27-2010, 04:41 PM
RamAir95TA's Avatar
You need to use a puller remover/install tool to pull off the stock one and reinstall the new one. Don't try to install a new pulley with a hammer. Having the right tool is invaluable in this situation.
Old 07-29-2010, 11:56 AM
So can this be done while the power steering pump and pulley are still on the car? Do you have to remove any other parts to get this tool into the location to remove the pulley?
Old 07-29-2010, 12:22 PM
RamAir95TA's Avatar
To be honest I'm not sure (never removed my pulley). I am positive that it will make life a thousand times easier to remove it though.
Old 07-29-2010, 01:59 PM
1993 z28 f1's Avatar
Hey:
How about this stuff,
http://s884.photobucket.com/albums/a...ody/?start=all
Somebody had a price list of this on here in the last few weeks
Dub
Old 03-29-2012, 11:48 PM
T/A KID's Avatar
Bringing this back
Is this pulley wider than stock? Doing a rib conversion on everything and I am not sure If I need to buy this pulley or not?
Old 03-30-2012, 01:39 AM
greendrazil's Avatar
turn one has one as well
Quick Reply: LT1 aftermarket power steering pulley or cover?
