im planning on doing a th400 swap
Old 07-28-2010, 11:28 PM
xdanny510x's Avatar
Question im planning on doing a th400 swap
like the title says im planning to do a th400 swap and im a litto bit confused LOL.. Im looking to get one from craigslst and have it rebuilt.. but they;re so many different years LOL.. is there any difference between one from like a 70ish to like a 88ish or somethin ?
Old 07-30-2010, 11:13 PM
Jays_SSZ28's Avatar
Not really. '71 and older had sprag type direct drums. Newer years can be upgraded with a 4L80E sprag type drum. At some point they switched from aluminum apply pistons to steel.
They also came with bellhousings to fit everything from chevys, buick/olds/pontiac, jeeps, jaguars, etc. It's not worth trying to adapt a non chevy bellhousing to an LS engine.
Old 07-30-2010, 11:34 PM
MASS seller approved
smok'nZ's Avatar
buy a built th400 not a used stocker
Old 07-31-2010, 12:13 AM
xdanny510x's Avatar
im gonna buy a used one and have that one built thats why im asking
Old 08-03-2010, 10:04 PM
ls6427blown's Avatar
are you going with a ultra bell
Old 08-04-2010, 06:59 AM
Detroit Gearbox's Avatar
Let the shop thats going to build it supply the core.
Not sure what the going rate in CA is, but a used core sells for 75.00 in the detroit area.
Regardless what core you but its most likely going to need internal hard parts.
If I had a choice between buying late or early I guess I would buy a later core.
Look for heat treated splines on the pump stator.
