best thing, if anything, i can do to keep my tranny from failing?
Old 07-30-2010, 09:22 PM
02v8ta's Avatar
Default best thing, if anything, i can do to keep my tranny from failing?
I have a 02 trans am. Mainly stock expect induction and exhaust work. I'm experiencing some of the common tranny problems i've read about. slipping gears, not shifting right. This is only once in a blue moon driving on the highway but none the less. Anything besides flushing the transmission? Best fluid to use?
Old 07-30-2010, 11:09 PM
joecar's Avatar
Have you checked the fluid level...?
Old 07-30-2010, 11:37 PM
fleetmgr's Avatar
Use a full synthetic fluid. Flush every 30k miles. Put an external cooler on the car. Heat in the tranny will kill it quicker than anything else.
Old 07-30-2010, 11:51 PM
02v8ta's Avatar
Yes, level is within normal range but it hasn't been changed in the 30,XXX i've put on it. It's getting flushed soon that's why i was asking about best fluid to use.
I was looking into external coolers but couldn't really find anything useful online. Any good websites to check out for these?
Old 07-31-2010, 12:16 AM
fleetmgr's Avatar
http://www.summitracing.com/
Old 07-31-2010, 01:47 AM
BennyB's Avatar
flush the tranny and put an external cooler on it the 26000 b&m is the one most run on these cars i believe
Old 08-03-2010, 06:26 PM
superman2002's Avatar
Wha t gear is slipping this trannys have a problem of burnin the clutches in third gear but definitly put an aftermarket cooler .
Old 08-03-2010, 08:11 PM
Circle-D's Avatar
Cooler, Cooler, Cooler....
Heat is the biggest killer in a transmission, especially the 60e.
Chris
Old 08-04-2010, 07:33 AM
2slow2flurry-ous's Avatar
If it's slipping already, it might be on it's way out. I broke mine inside of two weeks after installing my cam, and mine had the b&m cooler on it. Good luck, but if you enjoy the pull of the ls1 and your car has 80+k on it without a cooler, it's probably already toast.
Old 08-04-2010, 12:16 PM
twitchtwice's Avatar
i would change the fluid once a year. get a cooler, and install a shift kit as well. thats what ive done with mine and ive had a stall in for a year now and the car still shifts like a champ.
