LT1-LT4 Modifications - what timing set to get? best one?
ryanosborne
07-31-2010, 12:49 AM
im getting my engine re done and getting a cam kit very soon and im trying to figure out all the parts i need.. i was told i should get a new timing set while im doing everything else. would this be a good choice?http://www.summitracing.com/parts/CLO-9-3151/ what else would i need with it?
LSWHO
07-31-2010, 01:26 AM
If you're spending that kinda cash get the gm one
robsquikz28
07-31-2010, 01:35 AM
If you want I have a like new timing chain kit that came off of a heads cam car. THe chain kit has very low miles. Pm me if you want it. I will sell it to you cheaper than you can get one for new. Its literally like new still
1993 z28 f1
07-31-2010, 07:19 AM
Hey:
It is probably cheaper to buy an CSR electric water pump, and a STD Cloyes chevy single/double roller timing chain set, and Plug/weld the WP hole up, than it is to buy that set.
Dub
shbox
07-31-2010, 07:20 AM
Choices depend on what opti and water pump you are using. You don't give any info.
ryanosborne
07-31-2010, 10:45 AM
stock water pump and im ordering a msd optispark 1 .
RamAir95TA
07-31-2010, 01:12 PM
You have a billion choices.
-Stock non-vented opti with stock timing set. This is the least expensive easiest option, not to mention your only option without converting to a vented optispark.
-Stock non-vented opti, stock timing set, electric water pump.
-Convert to a vented opti, run a Cloyes double roller, and an electric water pump. This requires the most work, but will provide the most substantial gains.
PS - none of your options should include an MSD optispark.
ryanosborne
07-31-2010, 01:54 PM
so i should get a acdelco optispark? where should i get the stock timing set? you said ai would be able to provide one fo rme
Valkyn
07-31-2010, 02:15 PM
You could get the LT4 extreme timing set and keep your stock water pump. Thats what I did.
Badazz 97 TA
07-31-2010, 02:19 PM
What year is the engine or what year is the car?!!!
RamAir95TA
07-31-2010, 02:20 PM
Go with the AC Delco opti. You answered your own question. :lol: Just ask them.
Only if the OP chooses to upgrade to a vented optispark setup. He has an unvented opti. At the same time, it would actually be cheaper to pick up an electric water pump and run a Cloyes double roller if he DOES choose to upgrade to a vented opti.
Valkyn
07-31-2010, 02:33 PM
Ah didnt know that. Thanks
ryanosborne
07-31-2010, 05:08 PM
what cover and rotor would i get for the ac delco opti?
RamAir95TA
07-31-2010, 05:17 PM
No need to change the cap and rotor on the AC Delco.
ryanosborne
07-31-2010, 10:50 PM
No need to change the cap and rotor on the AC Delco. ok sounds good thanks alot
