Taking off supercharger, what do I need to be stock again?
Ok I'm pulling off my blower to put on a nitrous outlet plate kit, I have a k&n CAI and soon a LE1 elbow, what else will I need to do to take off the blower? Do I need any other stock peices?
What can I add? It has 1.6 RR's, 52mm TB, headers, cat-back, what else is there to do besides H/C? If I go that route I want nitrous anyways and yes I would like to sell the powerdyne blower.
well i guess if heads and cam is the way you wanna go then do so that way and idk if i want a powerdyne i posted up on her about it asking how they are and if it was worth money and everybody said get procharger or vortech soo idk how much would you ask for it ?
Well first how much power are you making with the Blower? What are your mods with the blower? How much boost are you running? What is your goal with the car, track, horsepower, street or all of the above. You should be making some good amount of power with a blower unless you dont have the supporting mods to make tha power...check out my questions and well go from there
this.
Also, cut-out and a blower cam would be a good idea for more power...
If you still on stock fuel system it could something simple as adding bigger injectors, a tune and a walbro and youlll be making past 400rwhp. Considering you have a healthy engine and no problems with it.
i bet you need a good fuel pump, fuel pressure regulator, and some 30lb ford injectors and a good tune..
didnt see you list long tube headers for a mod.. you need them if you dont have them..
