Tune LS1 pcm for LS2 knock sensor setup
Old 07-31-2010, 04:22 PM
pHEnomIC's Avatar
Default Tune LS1 pcm for LS2 knock sensor setup
I threw a 404 ls2 in my car and I had to relocate the knock sensor on the side of the block. I don't believe I have seen a single degree of knock anywhere and I am at a good amount of compression, 11.5ish.
What do I have to do to make sure they are picking up knock correctly?
Old 07-31-2010, 04:41 PM
TransWS6Am's Avatar
did u use the ls2 knock sensors or your ls1 knock sensors?
Old 07-31-2010, 04:53 PM
pHEnomIC's Avatar
Reused the ls1 sensors.
Old 07-31-2010, 05:02 PM
TransWS6Am's Avatar
hmm im not sure then, i used the ls2/ls3 knock sensors on my 416. iv picked up knock on them
Old 08-05-2010, 03:18 AM
pHEnomIC's Avatar
I have about 23* of timing at full throttle, should I just jack the timing up like crazy just to test if it will trigger some KR? if so, how much should i raise it?
Old 08-05-2010, 04:58 AM
sssalah's Avatar
I'm using the LS1 knock sensors on mine and they're reading knock when I had my timing set at 30 degrees. Now it's at 26 and reasing very slight knock occasionally.
Old 08-05-2010, 11:34 AM
wait4me's Avatar
As long as you set up the knock sensor type, then it should be fine. You would just have to adjust the sensitivity UP a little to make it hear it better if on the side of the block.
And Salah, your airport is crazy! I have never had to be bussed to the main terminal before in a different country like that. Nice country though. I had fun.
Old 08-05-2010, 05:14 PM
pHEnomIC's Avatar
How do you set the knock sensor type?
Also how do you sensitize them?
Quick Reply: Tune LS1 pcm for LS2 knock sensor setup
