Drag Racing Tech - What's 117.17mph good for?
SouthFL.02.SS
01-22-2004, 12:55 AM
117.17 was my trap in the 1/4 tonight.
I usually cut 1.8x 60's, but could not muster better than a 2.0 tonight :(
Anyhow, it's an M6 with 4.10's in the 10 bolt.
Would like to know what kind of ET I can aspire to with that mph.
Appreciate it. :usa:
taqwache
01-22-2004, 01:15 AM
mid to high 11s with a M6. what did you ET that night.
SouthFL.02.SS
01-22-2004, 01:25 AM
:( 12.4 on a 2.077 60'
My best has been 12.19 @ 115.72 on a 1.83
I launch and shift like an old lady! :bang:
Coach 02 A3 Z/28
01-22-2004, 09:22 AM
At the Thunder Shootout in Nov. I went 11.13 @ 117mph. 1.46 60ft. ;)
Coach
gator's 99TA
01-22-2004, 09:32 AM
all depends on your weight and shifting points. i have run 116.8 (not locked up) and ran 11.59 @ 3590 lbs.
SouthFL.02.SS
01-22-2004, 09:44 AM
Full weight SS T-tops, leather seats.
My shiftpoints should be within 6600-6800, but my shiftlight broke last night and I was shifting all over the place (anywhere between 6000 to the 6900 rev limiter- bounced a few times- not good). My stock tach is useless.
Overall, a very sloppy night for me.
2000WS6Vert
01-22-2004, 09:48 AM
I'd say it's good for proving that your shifting needs some work! :D
Just messing with you! Your car sounds awesome.....very mean sounding! :hail:
My last run I hit a 13.2 @ 105 with a 2.06 60'. I'm very pleased...especially with a stock 2000 convertible (lid and BGRA).
SouthFL.02.SS
01-22-2004, 09:53 AM
NICE!
Tally TransAm
01-22-2004, 10:37 AM
damn thats some killer cam only mph
good job
im headed to the track on sat, well see what happens
SouthFL.02.SS
01-22-2004, 10:43 AM
good job
Good luck!
unit213
01-22-2004, 11:13 AM
I used to run a 12.2 @ 117mph on a 2.0 60' in my LS1 on a 100 shot. Raceweight was 3,650lbs. Your mph for your power level is right on par. An 11.7 would be a good ET IMO for that mph given a moderate 60'. I know you're not out to cut any 1.5-1.6's so a nice 1.75 60' on drag radials would put you in the 11.7 second range. Powershifting will drop some ET and pick up some mph. I know you're a granny shifter though. ;)
2000WS6Vert
01-22-2004, 11:15 AM
"granny shifting...no double clutching like you should....." :D
apexman
01-22-2004, 12:54 PM
Hell, that is an awesome trap 02SS! Easy high elevens would have been yours last night with a 1.8 60ft or better. I think that is great with the 10 bolt still working. It is better to drive it home than bum a ride huh!
Derek
SouthFL.02.SS
01-22-2004, 01:33 PM
Derek
I have redefiined the term "granny shifting" by adding one more generation.
I "great-granny shift" .... :jest: Literally, with shoes slipping off on each shift! Gotta get me some shoes! (or at least use shoe laces..) :D
2001 Pewter WS6
01-22-2004, 01:57 PM
Coach
But that was in an A4... We don't trap as high but we sure can ET:D :D :D
BrokenLS1
01-22-2004, 03:24 PM
weight has nothing to do with it.117 mph is a reflection of weight and power.
mid to high 11's with a good 60'.
unit213
01-22-2004, 03:49 PM
You listening to the radio and sipping on a slurpee too?
Damian
01-22-2004, 04:06 PM
If you're shifting is that bad, you can count on another 2-3 MPH just out of a better driver...
Shifting is everything for MPH. The faster your shifts, the higher the RPM range stays IE: stays in the power range...
FWIW I have driven friends' car's as much as 3-4 mph faster just by shifting alone...
josh
my 3700 lb ta runs 11.80's with a 1.6 60 foot at 117-118
Hawkn01
01-22-2004, 04:44 PM
Stock internal bolt-on,A4, 3225# 11.40@117.38, 1.53 60'
unit213
01-22-2004, 05:00 PM
I remember when I used to trap 117mph. :tear: There so cute at that age. ;) :D
gator's 99TA
01-22-2004, 05:08 PM
did i just hear weight has nothign to do with it? lol, what a joke.
SouthFL.02.SS
01-22-2004, 05:17 PM
:flipbird: :D
unit213
01-22-2004, 06:33 PM
Weight doesn't have anything to do with it.
It has EVERYTHING to do with it. :)
Damian
01-22-2004, 08:51 PM
Especially when we're talkin bout a 3900 lb POS half-shaft snappin turd :P
99-LS1-SS
01-23-2004, 05:43 PM
Unit, what is your best time in the Cobra?
unit213
01-24-2004, 08:58 AM
You BASTARD! :guns: :D
unit213
01-24-2004, 09:00 AM
Unit, what is your best time in the Cobra?I'll let you know in the spring. It wouldn't be an accurate description of the car due to all the new mods. Put it this way, I could eat some taco bell while driving it to a mid 11.
SouthFL.02.SS
01-24-2004, 09:02 AM
Ah! So, that means I can drive your car to mid 11's!
unit213
01-24-2004, 09:15 AM
Absolutely! Maybe lower you slow shifting bastard. :D
SMOKIN01TA
01-24-2004, 02:34 PM
:jest: Absolutely! Maybe lower you slow shifting bastard. :D
SMOKIN01TA
01-24-2004, 02:37 PM
i ran 12.2's last night with a horible 1.8 60' on 11.5 streets at 114 mph :eek2: thats what happens with crappy track conditions. should have been 11.9x with a 1.6x 60'. you know the track conditions suck when you rip into 3rd any the rear breaks loose with et streets in a high 11's car. :cry:
Quik98Z
01-24-2004, 06:49 PM
I ran a 11.57 @ 117.8 with a 1.62 60 ft. I think you could run the same if not better.
racer88
01-24-2004, 07:00 PM
Mine went 11.94 @ 117 1.74 60' in 39 degrees all mods in sig. :nod:
Durien
01-25-2004, 08:28 AM
i'd say you could hit mid to high 11s... i trapped at 116.95 before the driveshaft broke on a bolton car
AINT SKEERED
01-28-2004, 06:37 AM
Hey South Fla.
I think you must have forgot my secret to leaving on Nittos
AINT SKEERED
01-28-2004, 06:40 AM
Hey Rodney, You going to No problem Friday the 30th? Me and Ben(ou812/z28 ) are going . He is the one that was parked next to you at the Thunder shootout with the 94 LT1 z28 with the intake sticking out the hood.
