need some advice
Old 08-07-2010, 12:10 AM
Cam95Maro's Avatar
Default need some advice
okay i replaced the coil in my car and the misfire in the engine is corrected so problem one DONE .... we drove it and it still falls flat on its face so we tested fuel pressure and when the key is in the "on" position and the pump is priming i got 40lbs of pressure ... when you turn the car on it goes from 40lbs to 27lbs so my pump is gone and or going .. im going to replace it but i wanna know whats a good brand to go with for a pump should i go back to stock or should i go to a upgraded one which is what i prefer even though im not all super power i wanna upgrade so i dont have to do it later so can someone suggest what kind to put in or what kind you got and your luck with it
Old 08-07-2010, 12:45 AM
Cam95Maro's Avatar
http://www.summitracing.com/parts/GRN-GM722-2/?rtype=10 is this a good one or should i look else where?
Old 08-07-2010, 09:42 PM
Cam95Maro's Avatar
None has any suggestion on a fuel pump to get ?
Old 08-07-2010, 10:42 PM
trippinholyman's Avatar
walbro 255?
Old 08-08-2010, 01:20 PM
Cam95Maro's Avatar
i was reading about the walbro and it said you need 13.5v to run it ? did i read wrong or do you need that?
Old 08-08-2010, 01:50 PM
aboatguy's Avatar
It doesnt need 13.5 volts however, running a bigger power cable IE racetronix harness will decrease the voltage drop and allow the pump to move more fuel/maintain pressure in higher horsepower setups. (its a sound performance mod that's along the same lines as the "boostapump inverters that increase line voltage to pump)
If your car is still stockish there are lower capacity walbros. Ensure you buy your pump from a reputable dealer since there are counterfeit walbros out and about (often found on Fleabay)
Mike
Old 08-08-2010, 03:54 PM
Cam95Maro's Avatar
thank you for the information ... is the granatelli one from summit anygood thinking about just getting that one and calling it a day i dont need a real good one i just want my car running again
Old 08-08-2010, 04:02 PM
LS1TECH Sponsor
Racetronix's Avatar
http://www.racetronix.com/RX-FLT1-FPKG-2.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 08-08-2010, 04:48 PM
Cam95Maro's Avatar
If I buy just the pump no harness will it still work well with out it ? Or will it be a little slow
Old 08-08-2010, 07:43 PM
LS1TECH Sponsor
Racetronix's Avatar
W/O the harness the pump will take a performance hit. How much of a hit and how reliable it will be depends on the condition of your factory wiring. The harness is cheap insurance even if you don't need the extra fuel pump performance it provides.
__________________
>WEB SITE<
Quick Reply: need some advice
