pickup tube fell off now i have a question
So my pickup tube fell off and I welded back on the pump. I was in the process of putting my pan back on when my buddy said I should pull it all apart and replace all the bearins. Its not knocking and I don't have any ticks. So what would you do if it were your motor?
i take it the engine is out of the car?
if its out of the car and has hi mileage, i would almost have to do a rering on it.. maybe put the thinner head gaskets on it to bump up the compression a little.. and i would probably put some better valve springs on it in the process..
I know that. I was fixing my oil pump pickup tube and my friend told me I should pull the motor to change all the bearings and I don't see a reason if its not knocking or ticking.
The motor never dropped below 15psi because I have a low oil pressure light on my Apilliar so I shut the car off and limped it home and then I smacked the oil pan with a rubber hammer and I heard the pickup tube rattling around. But if the bearins ARE in fact bad the motor will come out and heads,cam and some machine shop work will be done
Not so fast.
I drove nearly 300 miles and made 8 WOT dyno pulls without a oil pump pickup. No kidding.
I noticed prior to the trip to the dyno, that under hard breaking I got the low oil pressure light a couple of times for only a second. I dismissed it and went to the dyno. Returned from the dyno and say the light again and put 2 and 2 together and new there was a problem. I started to question the pickup so I banged on the bottom of the pan with a mallet and heard the pickup bouncing around and then had a heart attack. Pulled the pan, replaced the pickup, welded the **** out of it and fired it up and drove it around.
All appears to be good. At idle with 5/30 oil, I get 25 on the dash guage and 22 on the mechanical guage. At 5-6K RPM I have easily 60 pounds plus. I saw the low pressure light at least a half dozen times and saw the guage hit rock bottom too. Maybe I was lucky but I feel confident that there is no damage. I have seen were others were lucky and others were not.
So my bearings are fine. But I have another question.. my pickup tube is set at about 7 1/4 in from the boottom of my block to the bottom of my pickup. Is this correct or should I change it?
