Who is running a GM HOT CAM??? Love or Hate?
Okay so who is running a GM Hot Cam in their LS1? Post up comments about what you think about it. Any solid hp #'s?
Please don't post if you have NEVER used one.
VIDEOS WOULD BE A PLUS
1 Post
This **** is getting annoying. I see nut swingers talk about the eps cam in almost every thread. I would understand if someone was asking for suggestions, but sometimes people come across good deals (free/dirt cheap) and just want to know peoples opinions on the cam that they have. Sorry for the rant an thread jack just needed to vent.
i used to have a Hotcam, my car at the time had most of the bolt ons and made 375/378 to the wheels. i drove the car every day with no problems after it was tuned, and was still getting 30 mpg on the highway.
at the time my car was going 8.5s on street tires, and 8.000 on Nitto DRs in the 1/8
if you are on a budget and come across one for cheap it is worth it to me... i had a bunch of fun with my car with that cam in it, and it sounds good too!
wait...... was this about eps cams.........oh yeah...no.
only one guy readin so far that has a hot cam?
I guess it because its a old cam and nobody is runnin it....lol
I have one in my car. It's been in since the car was new and has 70,000 miles on it now, no issues. On the dyno it made power all the way to 6800rpm and was still climbing. Plus it sounds like a larger cam.
I don't have one either but I think you will find most who think its a lousy cam have never had one. Most guys who have it love it. Maybe because it doesn't have a fancy name!!! It is easy on the valve train as well and from the dyno curves I have seen it makes pretty good power.
the hot cam is a decent mild grind. but like someone else said, there are alot better cams out there in the aftermarket now. if i went through the trouble of swapping cams, i wouldnt just get a certain one just because it's the best deal, when u should be looking for the best performance.
either way u go, the hot cam is still better than stock.
I put the Hot Cam in my '02 TA when it had less than 500 miles on it back in late '01. I had it for about 10,000 miles and loved it. In today's LS market, I would not recommend a Hot Cam unless it was very cheap. With bolt-ons, mine made 399 rwhp SAE. Not a bad cam at all, but there are much better cams grinds out there. If you have access to one cheap, go for it.
I had both the hotcam and asa cam in my 99 SS. I liked the hotcam more, put out good numbers and made usable power. If you get cam and springs cheap go for it, you will not be dissapointed.
What's up with some peoples "my **** is better than yours" attitude. Thats old.
i know that there are better cams out there. I sure hope that someone has developed a better one than a hot cam from the early 2000's. That was 10 years ago.
HOWEVER....how can one say that I should be looking for a cam that puts out the best performance???
Unless your related to Ms Cleo then you probably dont have any idea of what I want.
I dont want the biggest and best cam out there. I drive it 50-60 miles everyday. The hot cam has a good sound in my opinion. I like it and apparently it puts out decent usable hp also. Isnt a cam choice supposed to be a personnal choice???
Everybody else.....thanks for the input! This being my first cam it makes me not as nervous to go through with it. I have def did my fair share of research on it but it means more getting opinions for those of you that have actually used one.
THANKS
THANKS
for the OP ,,, ask your self ... is it worth it ?
labour charge valve train upgrades blah blah ... for a sound u like ??
i like the way u think then #) ... i say .. Ecutout would be a good alternative scince you like the sound only !!
cheer's mate
cheer's mate
a cut out on a stock car IMO sounds like ****. I just want a little more thump and a little more HP. I don't want a race car.
Thanks for everyone else's input!!!
THANKS
THANKS
I have the Hotcam and for the last year and a half has done good by me.
I put down 373 rwhp and have run a best of 12.44 at 111.5mph.
My smallish stall is what is holding me back right now.
I am confident that that a good ss4000 stall would put me very close to the 11 second n/a 1/4 mile et.
My car is shifting at 6100 rpms also, so I might pick up a little by raising the shift points to maybe 6300, but I'm not sure.
It drives fine but will surge a bit when rolling to a stop or cruising thru a parking lot at idle. But part of that is because I have dropped the idle from 950rpms down to 750 rpms.
It has a nasty lope to it at that rpm.
Yes, it is an older design, but it works well for me.
