Torque Converter installation...
I just wanted to get some opinions or what yall think. Do you think I would come out better if I installed my tc myself or pay to have it done? The cheapest place i have found wants $300. I know that its going to be APITA! But would it even be worth doing it myself?
If its just the TC then plan on payin triple when you A4 goes out because no cooler. If your gonna dish out 300-500 bucks might as well buy all the tools youll need and consider it a learning experience... Hell, if you have friends maybe you can charge a small fee and make some money back..
I did mine with jackstands and a floor jack. Wasnt too bad. Its just like old school. Its just takes time thats all. It wasnt hard. You get to know your car alot closer. Im glad i did it.Saved me 250 to buy my cam and springs
i could see 300 for tc/transgo/transcooler/fluids and some tuning. i'd ditch the hpp3 stuff and use the transgo instead. Transcooler is defo must after having my tci ssf 3500 in i understand why the damn thing runs hot, you're cruising between 2000-3000 at any city speeds all the time.
The $300 is for the TC ONLY!!! Then they want extra for the trans. fluid! *** THAT!! I have the trans cooler but i figured I could do that myself. Ill probably just do it myself, I shouldnt be that much to have the exhaust welded back together. Thanks for all the input.
Yep! I've done alot of reading and there seems to be alot of people spryaing with the SSF3500. I also talked to TCI they thought it would be fine. Also I dont spray through the shifts, but it does what you said I guess I'll have to keep they spary Short & Sweet.
I did mine with hand tools, a small floor jack and jack stands, its really not that hard to do, just get a friend or two to help you steady the tranny when you drop it on the floor jack to put the converter in. The tranny cooler isnt hard either
Do it yourself! there is a write up also on the internet that will walk you through it. I believe it's under modernmusclecar.net or something like that do a search on it
LS1TECH Sponsor
Personally im glad i paid the $175 to have mine done...i did the shift kit and cooler myself though, but i had allen head bolts on my flywheel and the first one stripped out when he was doing it...had to use an air chisel to get it out...come to find out that bolt on the flywheel was too small thats why he had a hard time getting it out and had to air grind the hole out a bit to get the new bolt to fit...also he didnt drop the ypipe...thank god because when i did my header install by myself as well btw all 6 bolts connecting the ypipe sheared right off...made it easy to do my exhaust but wouldve been major trouble if i tried dropping my ypipe during the TC install...if it were up to me again i wouldve again taken it to get done but thats me.
lata
Bill
lata
Bill
D(irecto)r Pepper
Do it your self.
It is not hard and only takes a few hours. Plus you get to learn a lot about your car when you do the wrenching on your car.
Save the money... ask some questions and do it your self.
eazzie-peezie.
eazzie-peezie.
hazat allen sockets are the best, to hell with mac/snap on in that dept.
knowing your car will come from the tc install, but I paid a guy with a lift 250 to swap it and install a B+M cooler. It was worth it cause he didn't use any rubber hoses plus on the lift I got to "know my car" pretty well without swearing at it. Depends on what you want - the 250 or a painless/clean install. My time is valuable to me so I paid the man. Also, now HE is intimate with my car which will help when HE installs my headers
I agree that it would be very doable for someone with the car high on jack stands with long extension and swivels.
