fuel pressure
Old 08-16-2010, 10:18 AM
jay97lt1's Avatar
Default fuel pressure
what should fuel pressure be on a 97 z28 mine is 42 at idle but drops to 35 when I rev it up Car has lost power I have replaced the opti and intake gasket
Old 08-16-2010, 11:58 AM
RamAir95TA's Avatar
~43.5psi key on, engine off, then it should drop 3 to 10psi with the engine running and slowly increase with throttle position.
Old 08-16-2010, 01:18 PM
jay97lt1's Avatar
It has 43 idling and will drop to 37 reving it.Its backfiring at low rpm and has no power
Old 08-16-2010, 01:24 PM
Badazz 97 TA's Avatar
37 is low. It should go up when revving, not down
Old 08-16-2010, 02:23 PM
idformula's Avatar
Unplug the fuel pressure regulator and see what it dose
Old 08-16-2010, 02:30 PM
blown94's Avatar
Likely the same thing. Sounds like the pressure regulator crapped out.
Old 08-16-2010, 02:37 PM
jay97lt1's Avatar
it doesnt change much when unpluged 1-3 psi
Old 08-17-2010, 02:22 PM
blown94's Avatar
its possible the pump itself just cant keep up anymore.
Quick Reply: fuel pressure
