what i should tune when installing Trick Flow® 515 HP GenX ™ Top-End Engine Kits for
Hi,
Could you please tell me what i should tune after installed that kit. I am newbie about this tuning....
your going to need a serious tune after that kit hope you have headers to. might want to call frost he does alot of mail order tunes hangs out on ls1.com alot.
ok, thanks
What you are thinking about if i put milder cam on it that TF 500 hp top-end kit whit that 220/224 cam, i have heard that i would be much easier to tune..?
Gonna be tough to find somebody over there but you really need somebody with HP Tuners or EFI live software etc... to do it right.....
It can be tuned without a dyno but needs to be by somebody who knows what they are doing with such major upgrades you are making...
Jep, What you are thinking about that cam?
Camshaft specs are 228/230 duration, .585 in./.585 in. lift, 112 lobe separation angle.
i have ordered ARH LT`s whit "off road" style + Catted Y pipe, also ported ls6 oil pump and ls2 chain
don't buy that kit ,you will get a better kit for a better price at vengeance racing.the tfs kit is crank hp,I have seen the VR kit make 460 rwhp.go to vengeance racing website and shop around.
LSX Mechanic
If you're using HPtuners, you need to visit their forum and read the stickies. If you're using EFI live, do the same thing. Most of the basic things you need to know are in the stickies and already answered for you.
Before attempting ANY tuning at all, you need to read read read. Then when you're done reading, read some more and buy a wideband. You cannot tune wide open throttle correctly without a wideband sensor.
Good luck.
Good luck.
