Starter problems. Heat soak???
Old 08-19-2010, 08:43 PM
cookietime's Avatar
Default Starter problems. Heat soak???
This is the third starter since december.
Its a freaking project car, I only drive on weekends.
The car staarts fine when cold, but when it heats up , and i shut it off, just clicks until it cools down.
The car has a 160 stat in it and rarerly goes over 180.
This last starter i got in just mid july! wtf???
Is anyone else having this problem?
Battery is new , with all new battery cable ends and , ground is tight and secure, on motor.
Stumped!
Old 08-20-2010, 03:38 AM
brucer's Avatar
what brand starter? did you check the clearance on the flywheel/flexplate? you might need to shim it..
Old 08-20-2010, 09:01 AM
quik95lt1's Avatar
i had this issue with my starter.......stupid autozone crap.........they were lifetime warrantys so i just kept replacing them........i finally broke down a bought an MSD APS starter......of course 13.9:1 CR probably wasn't helping lol...
Old 08-20-2010, 12:24 PM
RamAir95TA's Avatar
Do you have headers, and where are they in relation to your starter?
Old 08-20-2010, 12:40 PM
JAKEJR's Avatar
On my previous 415 SB I did a couple of things: I wrapped the headers in the area of the starter with heat resistant wrap and I installed a solenoid heat shield bought from AutoZone (less than $10). Cured my heat/starter issue.
Jake
Old 08-20-2010, 12:50 PM
cookietime's Avatar
I have elderbrock shorties, connect into factory y pipe,through
hollowled cat, dumping into magnaflow
Old 08-20-2010, 01:01 PM
RamAir95TA's Avatar
You still didn't answer my question...where are they in relation to the starter? Are they close to it (within an inch or two)?
Old 08-20-2010, 03:12 PM
Slowmaro95Z28's Avatar
A cheap heat shield for the starter should solve your problem. Good luck.
Old 08-20-2010, 07:05 PM
IronOutlaw's Avatar
I have hooker shorties and my starter is dangerously close to the header. Previous owner went through two starter and rebuilt this one twice. I just had to buy another one and am going to make some sort of heat shield for it so I dont have to buy another new one.
Old 08-20-2010, 07:25 PM
85iroc94ta's Avatar
Stumped!
i have the same problem with my new motor (12:1) turns over fine cold but turns slow than clicks when hot. i run about 180 also and have long tubes that are wrapped. i cleaned my ground and starter wires and a new battery also.
so let me me know what you find out
Old 08-20-2010, 07:40 PM
BlackBird87's Avatar
I have the same headers and theyre not that close at all, My starter just turns a lil slower after being ran i just havent gotten around to putting a shield on it
Old 08-20-2010, 09:51 PM
JAKEJR's Avatar
Years ago, before the shields were readily available, I fashioned one out of a coffee can.
Ya do whatcha gotta do.
Jake
Old 08-20-2010, 10:11 PM
Jake
When i bought my car the guy before me wrapped anything that was near the headers with aluminum foil looked like a space ship under there
Old 08-23-2010, 10:33 AM
quik95lt1's Avatar
i had the same issue i bought an msd aps starter and clocked it away from the headers more.......plus i wrapped the headers and the starter.......problem is gone and the car starts up with 14:1 CR, 225* Coolant Temp on a 90 degree day with no issue at all....
Quick Reply: Starter problems. Heat soak???
