mahle power pack pistons?
Old 08-22-2010, 10:40 PM
SPOOLIN Z28's Avatar
Default mahle power pack pistons?
has anyone ever used these and made some higher numbers? i picked up a set couldn't pass up the deal and they are perfect for my 370ci motor but not sure if they will handle higher numbers under boost.
Old 08-22-2010, 11:26 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Are they meant for boost or compression? I assume boost. If they are forged pistons they should be able to handle a fair amount given what their application is for.
Old 08-23-2010, 08:32 PM
not sure if they were specifically made for boost but they are a forged piston. i will roll the dice and see how it pans out for me
Old 08-23-2010, 08:35 PM
89L98T56's Avatar
Make sure you get the correct size....I had a brand new set get ruined because the machine shop didn't set them up with the right PTW clearance.
Old 08-23-2010, 10:07 PM
havent had the machine work done yet but me and the machine shop work together on several other jobs/projects. they are top notch and take care of me very well
Old 08-23-2010, 11:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You may want to find out what CR those piston are. Are there any engravings or casting numbers on them? Check with Mahle as well.
Old 08-23-2010, 11:24 PM
i believe they will bring my compression to 8.9:1 with 72cc heads
Old 08-23-2010, 11:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
thats a handy piece of info right there.
Old 08-24-2010, 07:16 AM
slow trap's Avatar
with the right ring set and a spot on tune they will take quite a bit but they are still 4032 high silicone verses something made out of 2618. hit up someone more knowledgeable like hke or a reputable engine builder to the right > and see what they say.
Old 08-24-2010, 08:47 AM
Project382's Avatar
These pistons will handle 800-900 horsepower easy. Just remember nothing will deal with detonation well.
Old 08-24-2010, 08:25 PM
brooknasty's Avatar
Mahle power pak pistons are good and strong. Call Mahle for more info!
Old 08-24-2010, 11:23 PM
thanks for all the info guys. i plan on taking the motor and assy to the machine shop next week and go from there.
Old 08-25-2010, 12:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Let us know how it goes!
Old 08-25-2010, 11:19 AM
jmm98LS1's Avatar
I run those mahle's in my 370. It's nitrous instead of boost, but they're holding up great with ~700rwhp so far.....
Quick Reply: mahle power pack pistons?
