t56 want to put in a viper out put shaft
i have a t56 i am rebuilding for my car i bought it as a core and found the out put shaft has a bearing that has spun on the shaft so rather than replacing the shaft with the same one i should up grade. my question is what do i have to change to do the install of a viper out put shaft
Depends on what you pay for the parts. Mainshaft is a little less than $300 and then you need to have the tailhousing bored out for the larger rear bushing and seal. Those parts are about $15 give or take. Lastly, you will need to have your VSS modified to work with the Viper mainshaft. There are a few different ways to accomplish this and prices would vary depending on which route you go and who's doing the work on it.
I am doing the rebuild but i do not have any one to do the modifying i have a machine shop that could bore out my tail housing the VSS modifying i don't know anything about, is it hard to do
LS1TECH Sponsor
We sell a kit that has everything included that comes in our level 3 rebuild. The cost for that is $1329.99. If you only want the viper conversion stuff (mainshaft, modified reluctor, slip yoke for the driveshaft, modified tailhousing) the cost for that would be $700. This is with a brand new tremec tail housing already modified with the bushing and seal installed. Other places may require a waiting period to modify your tailhousing or have a core charge. We should have everything in stock and ready to ship.
-Jonathan
-Jonathan
