stock LT1 1/4 times..?
Old 08-25-2010, 10:42 PM
silverz28camaro's Avatar
Default stock LT1 1/4 times..?
My buddy has a stock 1993 z28 auto with I beleive 3.23 gears. I raced him today and it was side by side, I have video I'll post up later.
I was wanting to get my truck to the track but I would like to know what these cars run stock just to give me an idea of what the truck will do.
Old 08-25-2010, 10:46 PM
EliteCamaro94's Avatar
my 94 z28 ran 14.2 bone stock, its an auto with 2.73 rear gears though. Hope that helps
Old 08-25-2010, 10:54 PM
Big Bad Bud's Avatar
I ran a 13.98 @ 101 at Pomona Speedway 8 years ago or so. Basic bolt on's
1995 z
Old 08-25-2010, 10:58 PM
suicidal racing's Avatar
all depends on location..if your -800 for sea level with it being 50 out and no humidity then your going to run a killer time
Old 08-26-2010, 12:52 AM
RamAir95TA's Avatar
13.9@100 stock 10 years ago.
Old 08-26-2010, 08:56 AM
http://www.youtube.com/watch?v=pCokGdDVe1E
Old 08-26-2010, 09:13 AM
Vettestir's Avatar
I had a bone stock 93 and it ran from 13.90 @ 98mph backed up with a 13.91 same day to 14.21 @ 96mph depending on weather conditions. I had a bone stock 97 camaro and ran 14.09 @ 98mph and have a 97 TA (GF car) now that ran a best of 14.06 @ 97mph when it was stock. All auto's and full trim with spare tires and everything. The two tracks were I ran the cars are less then 600' above sea level and the best runs the DA was about 500'.
Hope that helps.
Now take it to the track and get some real numbers.
Old 08-26-2010, 09:33 AM
Village Troll
SS RRR's Avatar
This is the truck with the LS1 in it? If so, anything done to the LS1 or is it stock?
Old 08-26-2010, 10:28 AM
Badazz 97 TA's Avatar
Ive personally seen at the track(not some internet bench racing that everyone does) anything from 13.9 to 14.6 with stock LT1's.
Old 08-26-2010, 11:20 AM
draggin97s10's Avatar
ive ran 13.98 to 14.30s stock LT1 with cut out...
Old 08-26-2010, 11:22 AM
CaptainDirtymax's Avatar
13.99@100mph on a 1.9 60'. bone stock down to the tire auto, 3.23 rear. and 190k miles on the drivetrain.
1993 Z28
Old 08-26-2010, 12:49 PM
Stock ls1 in the 1988 dodge ram in my sig. Motor has ebay headers, and homemade CAI. The shift points are messed up and the spark plugs are original with the 98 LS1. It needs tuned bad, but runs well for what it is. Weight was 4,400 with the pass. and the truck has 3.90 gears with stock stall in the 4l60e. 31 in mud tires.
Old 08-26-2010, 02:46 PM
96lt1m6's Avatar
My '96 Z m6 stock tires 14.6 3000'DA
Old '95 formula m6 stock tires 14.7 no mods to either car and both were run in the summer heat.
I have personally seen Lt1s run 13.5-13.9 at HRP,1993-1995 when they were new.Gotta love sea-level
Old 08-26-2010, 03:37 PM
z_speedfreak's Avatar
theres a swap you don't see everyday! nice truck man
Old 08-26-2010, 03:54 PM
NewOrleansLT1's Avatar
You should have put a Hemi in there...
Old 08-26-2010, 04:25 PM
trilkb's Avatar
ran a 14.4 last time i went to the track. nitto 555r's, flowbastard, ebay intake, intake elbow jammed into throttle body. various leaks, 125k miles stock opti im sure.
Old 08-26-2010, 04:39 PM
ElkySS's Avatar
mine ran 13.7 bone stock. but mines an m6.
Old 08-26-2010, 07:30 PM
I get that alot, but, I only have $1700 in this swap, sold the 440 and all 440 stuff for $2,400.
LS1's are very common, plus they have aluminum blocks, vs. the 5.7 hemis cast block. The LS stuff Is much more popular and seems to be the smart choice for anyone on a budget.
Look around and let me know if you find a modern hemi with computer, harness, transmission, and a passenger drop transfer case........good luck
Old 08-26-2010, 11:40 PM
slomarao's Avatar
A big factor in what a stock car will run is the driver. if you have a good driver with a m6 car your going to get the best result.
Old 08-27-2010, 06:43 AM
Village Troll
SS RRR's Avatar
This would have been a perfect example to use in the "dinosaur" thread. If anything this is a perfect slap in the face to those who believe the LT1 is on par with the LS1.
Quick Reply: stock LT1 1/4 times..?
