5000 RPM drop ????????
Old 09-01-2010, 05:45 AM
NAVY's Avatar
Default 5000 RPM drop ????????
Hello I've built a new engine 408 cid , After three days of running the engine went to test the engine here, where the shock is that the engine does not go over 5000 RPM with WOT.
i will change the Valve Spring and all the electronic parts ( cam Sensor , crank sensor , map , maf , ecm ) , fuel pump pressure 58 psi AFR 12.8 .
i need
Advice
Old 09-01-2010, 08:56 AM
blsnelling's Avatar
Does it idle and run fine to 5K?
Old 09-01-2010, 09:08 AM
1SLwLS1's Avatar
my TB was only opening 82% last time on the dyno. Looked like it dropped a cylinder after 5K and the tuner quickly let off. Adjusted the cable and it was good to go. Doubt this is your problem, but something to look at.
Old 09-01-2010, 09:15 AM
blsnelling's Avatar
You don't have any friends that would have changed your tune and set a 5K rev limiter do you?
Old 09-01-2010, 11:15 AM
NAVY's Avatar
about idle its ok
i will chack in the dyno TB opening 100%
same Problem 5000rpm not the highest
Old 09-01-2010, 04:00 PM
dudeiwin86's Avatar
did your tuner lock the tune to 5000 for you to break it in?
ive heard of people doing that to insure themselves a little with warranty on a motor they just sold and tuned to avoid it coming back broke the next day.
but... i would think he might have told you about it, lol.
