what exactly do i need for e.g.r delete and a.i.r delete
Old 09-02-2010, 06:47 PM
ryanosborne's Avatar
Default what exactly do i need for e.g.r delete and a.i.r delete
i have headers on the way without the sensors and a off road y pipe. what do i need now? e.g.r block off plates, and what size drain plug do i need and where can i get one and a 5/8 vacuum cap right? what exactly is a vacuum cap and what else would i need?
Old 09-02-2010, 07:12 PM
RamAir95TA's Avatar
What do you mean by "without sensors?" If you got the headers without O2 sensor bungs, you're going to have to have them installed. If you meant without AIR injection fittings, you're good to go (in which case you do not need any plugs).
A vacuum cap is just a rubber plug. You need a 5/8" cap to plug the hole left in the intake ducting.
The EGR is removed and blocked off with plates. You'll need programming to have the codes turned off too.
Old 09-02-2010, 10:44 PM
i have these hedders ordered, will my car still run normal without the programming and just have the engine light on or what?
Old 09-02-2010, 10:47 PM
http://www.summitracing.com/parts/PSM-72C2239/ these hedders
Old 09-03-2010, 12:02 PM
RamAir95TA's Avatar
The SES light will remain on, along with the cooling fans. The engine will still run fine.
Old 09-03-2010, 03:09 PM
so what will i need to delete it? what size drain plug?
Old 09-03-2010, 03:30 PM
rufrntn's Avatar
Someone should make a whole kit for it. I'm thinking about doing it myself.
Old 09-03-2010, 06:04 PM
RamAir95TA's Avatar
Maybe you should read my first post. All you need is a 5/8" vacuum cap.
Old 09-03-2010, 08:30 PM
tricked94camaro's Avatar
from my experience it will run like ****
Old 09-03-2010, 11:15 PM
MasterTomos's Avatar
Mine runs flawlessly without EGR/AIR
Old 09-04-2010, 08:40 AM
if you deleted it from your ECU then yes. this kid is talking about NOT deleting it from the ECU
Old 09-04-2010, 03:04 PM
you told me in another thread that i needed a m18 or m22 drain plug
Old 09-04-2010, 05:20 PM
RamAir95TA's Avatar
You ordered headers WITHOUT EGR and AIR hookups, so you DON'T need the plugs. You said nothing about non-emissions headers in your other thread. I assumed you had stock manifolds. Holy crap man, read:
Old 09-05-2010, 11:29 AM
ok perfect i just hope it dont run like crap without tuning out the egr and air for now.
Old 09-05-2010, 10:45 PM
has anyone had any experience with deleting the egr and air without getting it tuned out?
Old 09-05-2010, 10:54 PM
Tolley's94z28's Avatar
vacuum cap and an egr delete kit
Old 09-05-2010, 11:13 PM
Whittaker's Avatar
How do you get the SES light off? Besides tune? I pulled the relay and fuse? I know the sensor is there the rest is capped/blocked.
Would they even make headers for a 4th gen LT1 w/o O2 sensors?
Old 09-05-2010, 11:20 PM
RamAir95TA's Avatar
The SES light needs to be tuned out of the PCM for the EGR. Leave the fuse in and you won't get an SES light for the AIR pump on an OBDI car (some OBDII cars are hit or miss). What sensor is capped/blocked?
You can get headers without O2 bungs, but that makes absolutely NO sense for 98% of the people on the forum.
Old 09-06-2010, 08:50 AM
Z28Roxy's Avatar
Unless he has a 93-95, then he won't need stuff programmed out (unless he removes the EGR solenoid).
Old 09-06-2010, 11:01 AM
Whittaker's Avatar
Mine is a 95. I left the solenoid up along side the intake. All the air and egr is gone.
I have Tuner Cat but having issues getting it to read my ECM right.
Some one mentioned a resistor or ? from Radio Shack.
Quick Reply: what exactly do i need for e.g.r delete and a.i.r delete
