Need Advice: Oil in Radiator :-(
Old 09-03-2010, 05:55 PM
LT1559's Avatar
Default Need Advice: Oil in Radiator :-(
When i changed my head and head gasket on the passenger side I torqued it down with 3 passes going up to 65 ft. lbs according to the haynes manual. But when I read on the internet everyone was telling me to do 125 ft.lbs(or somewhere around there i forgot the exact number). What torque specs am I supposed to use? The car ran "okay" with no head gasket leak, but did have an oil leak due from not being correctly sealed at the rear of the intake manifold, it was also missfiring. occassionally the car overheated( i did not let it get past the 3rd tick) but i figured it was due to not properly bleeding the radiator system so i just kept filling it up with coolant thinking the airpockets would soon bleed out by me filling everytime with the car running and bleeder valve open, and i ran like this for maybe less than a month. then the other day i opened the radiator cap and found "chocolate milk".
Old 09-03-2010, 05:57 PM
speed_demon24's Avatar
Did you re-use the stock head bolts?
Old 09-03-2010, 06:01 PM
LT1559's Avatar
Speed_Demon - Bought new head bolts
ZL1 - thanks
Does anyone know why haynes says the 93-95 are spec'd to be at 65 lbs?
Old 09-03-2010, 06:03 PM
LT1559's Avatar
And if i were to do them again, would i have to remove the head gasket and get a new one or could i just re-use them and unbolt the headbolts, buy new ones and torque them down.
Old 09-03-2010, 06:04 PM
AZ2ENVY's Avatar
Absolutely buy NEW head gaskets again ! NEVER re use them . Depending on the type of head bolts you purchased some can be re used .
ZL1 - thanks
Because that's the correct torque. If you are using stock bolts the proper method is to use an angle gauge though.
Old 09-03-2010, 06:05 PM
Originally Posted by ZL1LT1
Never fully trust Haynes or Chiltons . Some of the info is bogus at best . Go with 125 ft lbs and be done with it
You should probably stop posting on this subject before you cause someone to ruin their engine.
Old 09-03-2010, 06:09 PM
I have been building LT1s since 97 and not once have I ever had a problem or
a come back . So from a professional builder standpoint thats what im putting on the table .
I really hope this is a joke. Why don't you go ahead and post your source for the 125 ft lb torque spec on head bolts.
Old 09-03-2010, 06:15 PM
AZ2ENVY's Avatar
EDIT : Wife was trying to relay my message so im on here now to fix what she said. The most ive ever torqued an LT head down was 80 ft lbs . Not 125 like previously stated . My apologies for letting someone type under my screenname .
Old 09-03-2010, 06:16 PM
RamAir95TA's Avatar
There is absolutely NO WAY you should be torquing your head bolts to 125 ft. lbs. That is ridiculous advice. Get some ARP 134-3601s and do them in 3 passes. 25#, 45#, then finally 70#.
Old 09-03-2010, 06:17 PM
WTF is your deal buddy ? Dont need a source , real world results is what delivers not some textbook info you get from someone .
Real world results from what? What testing have you done to come up with this torque spec that will pull the cylinders way out of round if the bolt doesn't strip or break?
I guess I shouldn't have trusted arp's torque spec of 65 ft lbs when I did my heads? And if you are using stock bolts the correct way to torque them is with an angle gauge not a torque wrench.
You are telling someone to torque his heads to TWICE the torque spec. Think about that for a minute...
Old 09-03-2010, 06:18 PM
AZ2ENVY's Avatar
Hey man read my other post I clarified what was previously said . Apologies for mistranslated info .
Old 09-03-2010, 06:20 PM
Icematrix69's Avatar
Old 09-03-2010, 06:21 PM
AZ2ENVY's Avatar
Roll your eyes all you want but I stated what happened . Good day sir
Old 09-03-2010, 06:23 PM
You could have come up with a better story than that.
Old 09-03-2010, 06:25 PM
brucer's Avatar
his deal is that 125ftlb is entirely to much.. call felpro or arp and ask them, and then tell me when you hear them laughing in the background..
i want to see you torque the head bolt down to 125ftlbs then take a pic of the threads in the block, or the block itself, or the bolt itself and show me the twist in the bolt.. thats near dbl the torque needed..
in my life i have never heard of anyone torquing a head bolt to 125ftlbs.. hell a bigblock head isnt torqued that high.. ive built a few engines in my 20+years of hotrodding and i've never seen a headbolt on any engine needing 125ftlbs of torque.. off the top of my head,if i remember correctly a big block head torques down at 75ftlbs..
RamAir95TA's Avatar
LMFAO. Blame it on your wife...
Old 09-03-2010, 06:26 PM
AZ2ENVY's Avatar
If any of you pay attention to any of my other posts you would know my wife is on
here almost as much as I am . I think the Hot Girls on Fbodys thread cleared that up lol .
Old 09-03-2010, 06:29 PM
AZ2ENVY's Avatar
Deleted posts for **** poor info ...
Old 09-03-2010, 06:37 PM
BlackBird87's Avatar
Perfect example that hot girls belong on the hood and not under it
Quick Reply: Need Advice: Oil in Radiator :-(
