Is a bad radiator the cause of my problem??
Old 09-07-2010, 02:12 PM
LT1559's Avatar
Default Is a bad radiator the cause of my problem??
I found oil in my radiator last week and i assumed it was my head gasket. But I checked the oil dipstick and it was clean with just oil and no coolant. But my coolant resevoir and radiator had a milky dark substance which I know for sure is oil. A mechanic told me that the radiator was bad and the cause of the oil being in my radiator is from my oil cooler? I’m not sure and I haven’t heard of this before so I want to confirm this.
Old 09-07-2010, 02:18 PM
SSPerformance's Avatar
Dose your car has a powersteering cooler?
Old 09-07-2010, 03:12 PM
jaycenk's Avatar
You can have oil in the radiator with out having coolant in the engine oil. The above question is the more important one.
Old 09-07-2010, 06:52 PM
LT1559's Avatar
hmm I don't think it has a powersteering cooler. Thanks for the input.
Old 09-21-2010, 02:14 PM
LT1559's Avatar
Do the LT1's have a built in oil cooler in the radiator?
Old 09-21-2010, 02:16 PM
LT1559's Avatar
or is the oil cooler inside of the oil filter sandwich adapter with the "in" and "out" lines running through it?
Old 09-21-2010, 02:25 PM
speed_demon24's Avatar
Find a new mechanic.
Old 09-21-2010, 03:17 PM
rat93's Avatar
well the oil cooler is on the driver's side under the exhaust manifold w/lines running into the radiator... radiators corrode from the inside out and often leave residue that you may be mistaking for oil...have you replaced your radiator? have you flushed your radiator?
Old 09-21-2010, 05:12 PM
LT1559's Avatar
Where can I find a new oil cooler? I have not replaced the radiator but I did flush it.
Old 09-21-2010, 09:45 PM
ace3166's Avatar
Usually oil in the coolant means bad intake gasket.
Quick Reply: Is a bad radiator the cause of my problem??
