Time for new valve springs
I have a '99 Trans Am, which was bought with the heads/cam already done. The heads are 5.3 truck heads, I'm believing not ported due to numbers.
Anyway, I was told that the cam is a 232/240 .598/.608 110lsa cam, comp custom grind. I'm guesstimating that the cam went in around 100k. It's running great now, but it has 135k on it, and I'm thinking that I'm a little over due for springs.
I'm not sure which ones I want to go with. What would be a good spring set up for a cam of that size?
I was thinking the Patriot Golds, but a friend told me to stay away from Patriot springs, and go with a Comp Cams spring set up to match the cam. He's a Ford guy anyway, but what springs to get?
Thanks,
4WOFURY
Thanks,
4WOFURY
I bought Patriot Gold Xtreme springs for my LS3 heads but they installed at a much lower height than advertised, and as a result would have reached coil bind with the ~.640 cam I intend to run.
If you buy Patriots (actually, any spring), at a minimum make sure that you measure the installed height and verify that you're ok. Don't just install them and assume that they're ok.
Well for the OP I would not run the Patriot Gold. There is a reason some sponsers on here have stopped carrying there springs. I have a buddy that had Patriot Gold Extreams with a .650 lift and he broke 1 just at 15k on them. If your wanting to get the best get PAC made with the best stuff out there. Just spend the extra money and not have to worry about it.Cheaping out is not a good idea when it comes to internal parts, if one of your valve springs fail you could really be in a world of hurt.
LSX Mechanic
The Patriot Golds .650 are a decent spring. After using a few sets of the Xtremes, I'm not as big of a fan of them anymore.
With a .608 cam there's tons of options that will handle that cam no problem. If you want a spring that will handle that lift all day long, and provide a lot lighter valvetrain then check out PSI springs. I run their single spring on LSL lobed cams (.610-.620) with zero problems, and half the weight/harmonics of a big heavy double spring.
LS1Tech Premium Sponsor
The PRC spring kits are made of higher quality material, and the small parts of the kit (seats and retainers) are held to a higher degree of quality control and tighter machining tolerances than their competitor's kits.
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
And by sponsers not carrying Patroit I was manly talking about Texas Speed. These guy have a great rep and will answer your questions the best.
Thanks for the recommendation! To be clear, we DO offer other springs and kits aside from the PRC (PAC, Comp, and Manley just to name a few)....just not the spring kit mentioned in the original post
__________________
Hmmm, weird people are now having issues with Patriot springs. I have a set of their Patriot Gold Duals on my 5.3 heads and have put about 50k miles on them without a single issue. I was plannin on throwin a new set on at the end of the year if they need replaced when we check them. Only reason I let them ride so long is b/c my cam isnt very aggressive & I havent seen any issues that would lead me to believe my springs are worn to the point of needing replaced just yet.
Did you check installed heights, Mike? No more lift than you're running, it likely isn't a big concern even if they are off....but on the more aggressive lobes with more lift, that becomes even more important! There could be many more of these kits out there that are setup improperly, but most don't check that to know that the retainer is cut wrong.
So is ignorance really bliss like they say???
__________________
I installed them right outta the box expecting everything to be on point & so far 3yrs/50k miles later I havent had a single valvetrain issue. I know this is typically a big no no, but for some reason I put my full trust in Bo/Gunnar & they came thru for me.
LSX Mechanic
I personally don't know anyone (other than some other reputable LSX shops) that takes the time to check spring height.
