For those of you that want to use the truck acc. with car intakes
Old 09-09-2010, 10:43 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
Default For those of you that want to use the truck acc. with car intakes
FYI for anyone wanting to do this. https://ls1tech.com/forums/new-produ...-270-99-a.html
We have found that the truck front dress fits the older style car chassis' much better than the f-body and it is more cost effective to use it anyways. Plus, using the car manifold makes the engine appearance much more desirable.
Attached Thumbnails For those of you that want to use the truck acc. with car intakes-truckfrontcarmanifold-clearance-small.jpg
Old 09-09-2010, 01:09 PM
-TheBandit-'s Avatar
There is a thread here with more info on this subject:
https://ls1tech.com/forums/generatio...-manifold.html\
Do you sell the belt, idler pulley spacer, bolt and washer separately? I already have the gen IV truck waterpump and idler pulley.
Old 09-09-2010, 01:27 PM
LS1TECH Sponsor
Yes, it would be $62.69 + shipping.
Old 09-09-2010, 01:30 PM
LS1TECH Sponsor
Thanks for putting that there by the way.
Old 09-10-2010, 08:30 AM
Pocket's Avatar
LSx gaskets are reusable, so no unless you damage one coming out
Old 09-10-2010, 09:30 AM
cutlass_455's Avatar
Has anyone ever used a FAST 102 with a cable TB and truck accessories??
Old 09-10-2010, 09:36 AM
LS1TECH Sponsor
I don't think it will clear the waterpump. The cable will hit pretty hard. Maybe if there was a spacer.
Old 09-11-2010, 10:04 AM
What about using a 4th gen F car water pump with the spacers and the truck idler relocator bracket at the same time??
Old 09-13-2010, 03:39 PM
LS1TECH Sponsor
I guess that would work too. You just have another place for water to leak with the spacers, but go for it.
Old 09-13-2010, 05:48 PM
Marcello7x's Avatar
Good deal, i just finished putting my car intake on my 5.3 with truck acc. Made my own idler relocation bracket[came out ugly but works] and the best for this at advance was $40. Could have saved time and had a better looking setup for little more.
Quick Reply: For those of you that want to use the truck acc. with car intakes
