11" wide wheel backspacing or offset, post pics!
Old 09-17-2010, 02:32 PM
01Blk*SS*'s Avatar
Default 11" wide wheel backspacing or offset, post pics!
Hey there, I would like to see cars with 11" wide wheels. Im looking to order a set of 19x11" wheels for my rear end which is narrowed 3" per side, and need to know what backspacing or offset looks the best. I dont want to cut bump stops out, but will BGH and roll fenders. I would like no rubbing issues at all as this car is my daily driver. Please post size of wheel, backspacing, offset, lowering mods, and pictures are always great!
thanks!
Old 09-17-2010, 02:55 PM
SSmoken's Avatar
heres my car with 17x11 w 315's. backspace and offset unknown. car is lowered with eibach sportlines. adj phb and rolled fenders are needed for my car. stock rear though. you should be fine.
Old 09-17-2010, 04:44 PM
01Blk*SS*'s Avatar
any way you could measure your backspacing when you get a chance? also pics from the rear would be good to see how far the wheel stick out.thanks!
Old 09-17-2010, 05:05 PM
9WhiteCamaro9's Avatar
Hey Smokin what kind of PHB do you have? if you dont ming me askin without highjacking the OP's thread lol
Old 09-17-2010, 07:26 PM
LPE 403's Avatar
thanks!
Or you could grab that big 'ol sticky and a calculator . I figure you'll end up with a negative offset. 11" wheels figure a +45 to +56 offset for a stock rear and you're going to narrow the rear by an additional 76.2mm. Unless my calc battery is hosed, I get somewhere between -31 to -20...DEEEEEP!
Old 09-18-2010, 02:14 PM
01Blk*SS*'s Avatar
I dont need a calculator to do simple man haha. Since the sticky gives a "range" for offset, ie +45-+56, that range determines how far the wheel sticks out or is sunken into the wheel well. The first line in my thread says " ...I would like to see cars with 11" wide wheels." The reason I want to see pics is so I can determine the specific offset in that range that I think looks best. Thanks for your math skills though!
Old 09-18-2010, 02:58 PM
LPE 403's Avatar
Okaaaayyyy...plenty of 11" wheels on here. Not sure how many with 3" narrowed rears though. You're going to add a spacer I presume and in search of offset options?
Old 09-18-2010, 09:19 PM
01Blk*SS*'s Avatar
I currently have a 3" adapter until I can figure out exactly what backspacing will look/fit best. I want to know what will fit for sure before I spend $3500. That's why I ask so many questions haha
Old 09-18-2010, 11:01 PM
Leedogg's Avatar
My torque thrust II's are 7.75" Backspacing. I also just bought a fab 9 narrowed 3"...so I need a 17x11 w/4.75 BS to locate the tire in the same footprint. According to summit- 5.00 is the best I can get- and run a 1/4" spacer.
guess i should add a pic. I would thing the BS'ing would be close to the same regardless of rim diameter. BTW- my car has rolled fender lips- but no BFH on the inside, though my jounce bumpers have been modified.
Attached Thumbnails 11" wide wheel backspacing or offset, post pics!-trans-am1.jpg
Old 09-19-2010, 12:54 AM
SSmoken's Avatar
umi adjustable
Old 09-19-2010, 03:51 AM
01Blk*SS*'s Avatar
this is the kind of reply im looking for! thanks man. Do you have any pics of the rear? I would like to see how flush the wheels are from the rear view. by jounce bumpers, do you mean bump stops?
Old 09-19-2010, 06:44 AM
Leedogg's Avatar
yes- bumpstops.
As for pics from the rear....I'll have to look through my Fquick account- as I am offshore. I'll post one up if I find one.
Old 09-19-2010, 01:06 PM
01Blk*SS*'s Avatar
^ I browsed your FQuick and could not find a good picture from the rear. thanks anyways!
Old 09-19-2010, 05:40 PM
Arc00TA's Avatar
I'm not seeing what you're getting at here, if you run a custom backspacing to compensate for the narrowed axle, its going to look just like it does with a stock axle. Are you trying to get a certain look since you're going to get custom backspacing anyways?
Old 09-19-2010, 05:48 PM
01Blk*SS*'s Avatar
Im going for the deep dish look in the rear and also drag wheels are easy to find with that backspacing too. I basically need the best clearance backspacing and pics for a 11" wide wheel so I can just minus 3".
Quick Reply: 11" wide wheel backspacing or offset, post pics!
