Who runs LE hardware on here?
Old 09-21-2010, 04:06 PM
LSWHO's Avatar
Default Who runs LE hardware on here?
Rollcall.
What do you have?
How does it run?
Old 09-21-2010, 04:30 PM
speed_demon24's Avatar
I used to I have an Ai setup now
Old 09-21-2010, 04:38 PM
LSWHO's Avatar
What did you have?
What did it run?
Old 09-21-2010, 04:48 PM
97Z28SS's Avatar
My car's still under construction but I have LE3 heads/ported intake/847 cam/LT headers & true duals. I don't have any rwhp/rwtq numbers or track times yet obviously but I'm looking for high 11's low 12's on motor.
Old 09-21-2010, 04:50 PM
LSWHO's Avatar
M6? You should shoot for a lot faster with that.
Old 09-21-2010, 04:54 PM
FASTFATBOY's Avatar
Originally Posted by LSWHO
What did you have?
What did it run?
OOOOOOOOOOOOOOOOOOOOSH!T!!!!!!!!!!!!
Le ported my crab pot weights.
Old 09-21-2010, 05:35 PM
What did you have?
What did it run?
LE setup
Only changes were the Ai setup and going from a ported intake to a stock intake
Right lane both runs.
Old 09-21-2010, 06:13 PM
AChotrod's Avatar
LE does my stuff. 11.68 @119.44 lots of room to improve on that but car is set up for spray now.
Old 09-21-2010, 06:38 PM
old93camaro's Avatar
LS1Tech 10 Year
LE here as well 415rwrh 445rwtq
Old 09-21-2010, 07:13 PM
355z28's Avatar
LS1Tech 10 Year
I run LE's stuff. I've ran 7.30's in the 1/8th with mid 1.6 60's and horrible weather. I plan on running 11.1-11.2 on motor this fall in 1200-1700DA (basically good weather around here)
I used to compare my car to Joe's AI car. But after realizing He's been able to run in negative DA, and has weight advandages over me, theres no comparrison at the moment.
My car:
383 12.3:1
LE2 heads
3600 Race weight
Full accessories with Air conditioning
Full leather interior.
100% stock suspension
hooker catback with no cutout
Corrected DA my car says it will run 11.20@121MPH. If thats true Joe's car is still faster. But with some suspension and if I WERE to do any weight reduction I do think I could get there.
My car in no doubt is a full blown street car. No linelock nothing. I did invest in an aftermarket torque arm, and a transmission crossmember to relocate it. With this suspension im hopeing to go faster. Time will tell.
Old 09-21-2010, 07:34 PM
FASHOOTER's Avatar
This is my second LE set up LE1 went 12.50's
My new LE2 set up 11.70 116.2
Full weight street car Just started playing with suspension I don't think high 11.50 low 11.60 out of reach!
Old 09-21-2010, 08:40 PM
StealthFormula's Avatar
For the past 2.5 years I've been running LE2 Heads (561 castings unfortunately) and a Bret Bauer 224 intake duration cam which is who did the cams for LE back then. It has been my favorite purchase to date for the car and has been exceptionally reliable. This summer I took it on a 6 hour roadtrip and then an 8 hour roadtrip over my gas efficient DD because I enjoy driving it so much.
My best pass so far has been an 11.47 at 119mph with a 1.5x 60' in the summer heat and my raceweight that day was 3360#. Car is an auto and has a stock bottom end FWIW.
Old 09-21-2010, 09:13 PM
robsquikz28's Avatar
le2 heads, intake and 228 cam. with a 200 shot on SBE 10.18 at 130 car is long gone, but I still see it on the streets of chicago
Old 09-21-2010, 10:17 PM
pyro719's Avatar
Check my sig!
Old 09-21-2010, 10:49 PM
BOLO's Avatar
Running a LLoyd Elliott set up here. Check out vid below and other vid @ youtube.
Old 09-21-2010, 11:21 PM
hitmanws6's Avatar
I have an LE custom grind and "ported heads". Engine should be in this weekend and dyno #s should follow soon. As far as I know one other guy is running this cam, said it has similar manners to the GM 847 except that it pulls down low as well
Old 09-22-2010, 10:07 AM
grn95t/a's Avatar
LE2's ported intake, custom grind cam, runs like a beast! first time out with a tight nitrous converter running on the motor she pulled an 11.86 @ 117. much better times coming soon!
Old 09-22-2010, 10:40 AM
wrd1972's Avatar
LE2's and a 224/230 cam just like Stealth.
390RWHP through the 9". Probably would have broke 400RWHP with the 10 bolt.
Old 11-24-2010, 10:27 PM
djm_e22's Avatar
403rwhp 387lbs SAE through LE1, 306 cam, m6, and a 9" rear end. Went 11.6s. Know I could have hit 11.5s and possibly 11.4s but I sucked at shifting which is why I have switched to an auto.
Old 11-24-2010, 10:37 PM
SoxXpupPeT's Avatar
Just le's 223/230 cam but i Love it! Hes a great guy to talk setups too
Quick Reply: Who runs LE hardware on here?
