Valve Guide Replacement
Old 09-26-2010, 05:41 PM
blsnelling's Avatar
Default Valve Guide Replacement
How are the valve guides replaced in a LS engine? I saw pics of replacements from Trick Flow, and they appear to be threaded in. I thought they were pressed in.
Old 09-26-2010, 06:44 PM
blsnelling's Avatar
Well, the old valve guide just drove right out. So what's up with this threaded guide from Trick Flow, LINK? So now, how do I install the new one. Does the head have to be heated, or can the new one simply be tapped in? I'm sure there's a special tool to drive it in with.
Old 09-26-2010, 07:41 PM
soundengineer's Avatar
that thread is not for screwing in.. if for holding valve seals....threaded side sticks up...
valve seals press onto and lock onto the ribbed threads(notice they are not angled...just a straight wrap around)
pretty standard for aftermarket valve guides
Old 09-26-2010, 08:05 PM
blsnelling's Avatar
Thanks for the explanation. Makes more sense now. So where can I source a guide and install tool?
Old 09-26-2010, 08:16 PM
Jegs/Comp Cams/Summit..
everybody who sells tools for engine building carries one...
might need an air hammer too...you can do it without...but I dont recommend it
Old 09-26-2010, 08:21 PM
blsnelling's Avatar
The only guide I found at Summit wouldn't be shipped for nearly a month. I've found nothing on an install tool. Links would be great if you have them.
Old 09-26-2010, 08:24 PM
I mentioned 3 places.. try all 3.. I cannot guarantee anybody stocks them.. I am not a sales person.
try google....I found about 30 places that sell the tool.
Old 09-26-2010, 08:35 PM
blsnelling's Avatar
Mind sharing one of those 30 that you found? Perhaps I'm not searching for the right thing. I found nothing on a valve guide at Jegs or Comp Cams and only one at Summit. Nothing at all on the install tool.
Old 09-26-2010, 08:44 PM
http://www.jegs.com/webapp/wcs/store...e+intsall+tool
2nd item.. made by manley.. not cheap
Old 09-26-2010, 09:40 PM
Steve Gunn's Avatar
I had a guide replaced, heads inspected, lightly surfaced and cleaned for 100.00 labor from a local machine shop in 2 days. May be your best bet if you're in a hurry.
Old 09-26-2010, 09:53 PM
blsnelling's Avatar
These heads are completely cleaned and ready for assembly. All I need is 5 minutes of labor to install a $10 guide.
Old 09-26-2010, 09:54 PM
...with a $350 tool...
Old 09-26-2010, 09:57 PM
blsnelling's Avatar
There was no pic of that tool. I can't see a punch costing $350. Bottom line, these heads don't need any cleaning, resurfacing, or anything else. Just needs a guide pressed in.
Old 09-26-2010, 10:08 PM
blsnelling's Avatar
This is along the lines of what I need to install the guide. Sure doesn't cost $350. LINK
Old 09-26-2010, 10:11 PM
http://www.cylinderheadsupply.com/
http://www.cylinderheadsupply.com/va...tallation.html
whole sets for a lot less..
I'm guessing the manley one has something extra special about it that is probably for machine shops
again.. a simple google search...
please learn how to use the internet
Old 09-26-2010, 10:19 PM
Bo White's Avatar
The seat will need to be recut once the new guide is in place.
Old 09-26-2010, 10:24 PM
blsnelling's Avatar
Please don't reply to the thread if you don't want to help. I ask you where to find a $10-$15 tool, and you point me in the direction of a $350 tool. Doesn't seem like you know what you're talking about here. BTW, I do know how to use the internet. I'm a 42 year old software engineer. Just because I don't know where to find a specific tool doesn't mean you need to talk down to me. If you have something to add here, please do. Otherwise, take your trolling else where.
Old 09-26-2010, 10:26 PM
blsnelling's Avatar
To ensure the valve is seating properly? Makes sense. Thanks.
Old 09-26-2010, 10:35 PM
Bo White's Avatar
Yes, once you press/knock the old guide out and install the new one things move.
Quick Reply: Valve Guide Replacement
