Did I adjust my rockers right?
I installed the Hotcam kit. With the rockers I spun the pushrod until I felt resistance, then turned the nut a 1/4th turn.
The car runs, but I don’t know if I should re-adjust.
how did you do this, running or not? what type of roller rockers?
I like to set the rockers with the motor running.
1. loosen them till they "clack"
2. tighten till they stop "clacking"
3. turn less than 1/4"
4. tighten allen head ,hold the nut from spinning,
5. turn a smidge more to seat everything
6. WOT give her hell
You should have had to turn the crank to do it right.
btw, I'm obvoiusly talking about doing it with the engine off.
2x Vote
Yep - on stock lifters, 4 1/2 flats or 3/4 of a turn, per an ASE-certified GM master mechanic.
Most guys use too little preload based on something someone said at one time or another, but I'm not going to join that fight yet again.
Here's what you need to know: The MOST IMPORTANT PART of setting lifter preload is to make ABSOLUTELY SURE the lifter is riding on the camshaft's base circle/heel. If that's wrong, everything else that follows will be wrong.
Jake
Jake
Jake
Jake
This is why I prefer to get them as close as possible, then fire up the engine, let it FULLY warm up, then re-set them with the engine running. As "great421" said, GM shop manual calls for 3/4 turn past "zero lash", but that's with GM lifters.
I think what "JAKE JR" is getting at, is the Comp Cams 875R lifter setting, which is 1/8 turn preload MAX, per conversations I personally had with two different Comp Cams tech reps. HOWEVER, trying to accurately set that small amount of preload is a "whole 'nother story". Believe me, as I had those lifters in my car for a while, and it took 3-4 times before I got it where they weren't 'clattering', but not too tight....
Village Troll
And yes, OP. If you did as such knowingly doing so on the base circle of each lobe then you have nothing to worry about. If you don't know, then you should adjust them again. Shoebox has several methods on this: www.shbox.com
IMO wiggling the pushrod up and down will give you more consistent results of finding lash over twisting.
Village Troll
