flycutting?
flycutting?
what determines when you should flycut or not? the ptv? on a set of stock 243's, what cam is to big? would a 236/232 need flycutting or would i need the valve intake/exhaust be the determining factor? if so cam guru's could a cam be spec'd for me in the reverse split category that won't need flycutting. thank you
john
john
Why do you seem set on a reverse split right off the bat??? Why not just get somebody to spec you one????
To answer part of your ?? yes PTV determines whether to cut and yes that cam will clear uncut heads with GM MLS gaskets just fine prolly even on a tight LSAwith some advance....
Intake Center Line (ICL) Will you be installing the cam straight up? Is there going to be advance or retard ground into the cam? All of these will effect PTV. To give you an idea of what JPH is referring to is a Tr230/224 111 Lsa has an ICL of 111. Tr230/224 111+2 lsa would be a 109 ICL. A Tr230/224 111-2lsa would be 113 ICL. Why 116 or 117 Lsa? Why not call Geoff Skinner@ http://www.engpwrsys.com/ ? I think he actually designed the TR230/224. I'm sure he can help you.
well here in cali our LEO's pay extra attention to the cars with the lope and then soon after it's hi mr. smog ref i figure with a 116 or 117LSA and a lift under .600 on intake and exhaust my car shouldn't draw much attention with the stock catback. i think i'll give him a call or email on monday and discuss more about this with him, thank you!!!!
King, check out this very old thread by Nineball.. MTI put a reverse split 230/227 591/571 112 in a 422..
https://ls1tech.com/forums/generatio...o-results.html
Check out this link.. cam only LS2 GTO with a 244/241 cam making 470rwhp and 430 torque STOCK HEAD!!!!
http://www.alabamaracingscene.net/fo...ad.php?t=51858
oh i'll be sure to post up something when i concrete things ya know
Pred Z had suggested the 230/224 reverse cam for my Firehawk. I was going to use the stock intake/heads and headers. After I picked up a LS6 intake and a set of TEA 5.3 1.5 heads I talked to Geoff who I think actually designed the TR 230 cam. I ended up with a 226/230 .598/.600 112+2 installed on a 109.5 ICL. No donkey dickin here.
