flycutting?
Old Oct 8, 2010 | 09:33 PM
King Nothing's Avatar
Default flycutting?
what determines when you should flycut or not? the ptv? on a set of stock 243's, what cam is to big? would a 236/232 need flycutting or would i need the valve intake/exhaust be the determining factor? if so cam guru's could a cam be spec'd for me in the reverse split category that won't need flycutting. thank you
john
Old Oct 8, 2010 | 10:25 PM
SOMbitch's Avatar
Why do you seem set on a reverse split right off the bat??? Why not just get somebody to spec you one????
To answer part of your ?? yes PTV determines whether to cut and yes that cam will clear uncut heads with GM MLS gaskets just fine prolly even on a tight LSAwith some advance....
Old Oct 9, 2010 | 01:44 AM
i have a hard on for reverse split cams and i like to be different originally years ago i was goin to put in a 230/224 but i got scared because of the LSA so i got the 227/224 instead and i only got 300 miles out of that and never went past 2500rpm before i hydrolocked the engine the new owner of that cam was tellin me how hard it pulls and if that pulls hard i can't wait to see a larger reverse split cam. either 230/224, 230/227 or 236/232
Old Oct 9, 2010 | 09:32 AM
JPH's Avatar
JPH
The intake side is what you will need to be concerned with. What LSA are you going to run and what ICL will it be installed on?
Old Oct 9, 2010 | 01:36 PM
LSA will be 116 or 117 and the ICL??? are you talkin about lobes? if so they'll be the same as the TR230/224. this is why i asked from cam guru's or really anybody with cam experience so i can pick the best reverse split cam
Old Oct 9, 2010 | 03:31 PM
BaddBird's Avatar
Intake Center Line (ICL) Will you be installing the cam straight up? Is there going to be advance or retard ground into the cam? All of these will effect PTV. To give you an idea of what JPH is referring to is a Tr230/224 111 Lsa has an ICL of 111. Tr230/224 111+2 lsa would be a 109 ICL. A Tr230/224 111-2lsa would be 113 ICL. Why 116 or 117 Lsa? Why not call Geoff Skinner@ http://www.engpwrsys.com/ ? I think he actually designed the TR230/224. I'm sure he can help you.
Old Oct 10, 2010 | 12:59 AM
well here in cali our LEO's pay extra attention to the cars with the lope and then soon after it's hi mr. smog ref i figure with a 116 or 117LSA and a lift under .600 on intake and exhaust my car shouldn't draw much attention with the stock catback. i think i'll give him a call or email on monday and discuss more about this with him, thank you!!!!
Old Oct 10, 2010 | 01:03 AM
matrixiskool's Avatar
Yeah call him and do some research and give it time. Don't rush it and buy a cam and parts before you know what is going on for sure.
Old Oct 10, 2010 | 01:14 AM
i know i'm going with a reverse split and stock 243's . . . i just don't know what durations the cam will be on just yet. my buddy has my old 227/224 and he loves it, i wish i got to enjoy it before i locked my engine
TXZ28LS1's Avatar
King, check out this very old thread by Nineball.. MTI put a reverse split 230/227 591/571 112 in a 422..
https://ls1tech.com/forums/generatio...o-results.html
Old Oct 10, 2010 | 01:36 AM
Originally Posted by Nine Ball
bparker, tuning would be highly recommended. The last Stage 2 LS6 heads/cam with this X1 pulled 440 rwhp and over 400 ft-lbs.Tony
damn!!!!! granted it's a 6speed, still that is some good power
Old Oct 11, 2010 | 12:41 PM
awaiting my response from geoff any other input on this?
Old Oct 11, 2010 | 01:56 PM
LilJayV10's Avatar
I would go with whatever he tells you. I got my cam from him. He's a smart dude.
Old Oct 11, 2010 | 08:03 PM
sweet! i'll see what other questions i can ask him too
Old Oct 11, 2010 | 08:07 PM
mike c.'s Avatar
I thought the rev split cams were a thing of the past. I may be wrong,but i believe the fastes guys here run tradi-split cams. Being different,is just being different and maybe not the best gain. Good luck to you my different friend.
Old Oct 11, 2010 | 08:52 PM
TXZ28LS1's Avatar
reverse splits have their place. There is a reason why the MTI suggested their X1 over any other cams in daily driven street cars. Also thunder racing highly suggested the TR230/224 over the famous 224/224 cam. No doubt there are new grinds and probably better ones now.
Check out this link.. cam only LS2 GTO with a 244/241 cam making 470rwhp and 430 torque STOCK HEAD!!!!
http://www.alabamaracingscene.net/fo...ad.php?t=51858
Old Oct 12, 2010 | 01:37 AM
LilJayV10's Avatar
Let us know what he says.
They have their place. It's like anything else it depends on your combo.
From what I have seen from Predator Z's post is an engine with stock intake and heads.
Old Oct 12, 2010 | 02:03 AM
i don't see it as a way of the past, they aren't as popular as either the 224 or donkey dick cams. from what i've seen RS cam's can give you a broad powerband and i'd rather have that than a big cam that only gives me power in the upper rpms. for a DD it's a perfect cam from my understanding but i'll see what Geoff says about my plans.
oh i'll be sure to post up something when i concrete things ya know
Old Oct 12, 2010 | 02:36 AM
LilJayV10's Avatar
Pred Z had suggested the 230/224 reverse cam for my Firehawk. I was going to use the stock intake/heads and headers. After I picked up a LS6 intake and a set of TEA 5.3 1.5 heads I talked to Geoff who I think actually designed the TR 230 cam. I ended up with a 226/230 .598/.600 112+2 installed on a 109.5 ICL. No donkey dickin here.
Old Oct 12, 2010 | 11:36 AM
what power did you make and have you ran it at the track?
