looking for a good 355 bottom end combo for nitrous
well planning for the new motor has started, got the top and trans figured out but im still looking for what bottom end to go with. so what are most of you 355 guys running as far as pistons and rods (using the stock crank). thanks for the suggestions
Depending on the amount of nitrous you plan on using.........
I would stud the bottom end,H-beam 6"rods,Mahle pistons just for good measure have the rotating assembly balanced.
Have you decided on how the heads should be? AI or Le should be considered since GOOD HEAD always works and either will spec a cam to suit your needs.
MSD digital 6 to pull timing or have your tune N20 specific
What nitrous system are you planning to use?
www.nitrousexpress.com
www.nitrousoutlet.com
My setup should be good for a 225 hit with a good tune. I have speedpro forged slugs, forged scat i beams 5.7, ARP main studs, stock crank
im going with LE heads and cam and i have a nitrous outlet figger and a nx plate. dont now how much i will end up spraying but looking for the bottem to handle a healthy shot but nothing extreme.
program splayed mains, eagle forged crank, eagle 6" h-beams with arp2000's, je nitrous pistons with tool steel pins and hellfire rings. everything gapped and cleanced and balanced for a healthy shot. was professionally machined and built by a local race engine shop.
