Drag Racing Results - New Best, 1/8 N2o runs
View Full Version : New Best, 1/8 N2o runs
TA1364
10-11-2010, 08:24 AM
Car is Ms3/150 shot with stock 3.23 ten bolt, stock 4l60e with a shift kit, only suspension is solid lca, tires are 26x10 ET Drags. I ran 11.85@115 with a 1.65 60' on motor but could only run 1/8 on spray since I have no bar in it. I think this would have been a high 10.60
1.48
6.77@101.7
Chattered the tires a little bit off the line and didnt spray through the shifts, I think theres another couple hundreths left fixing those things.
blwn_00gt
10-11-2010, 09:34 PM
nice what converter you using?
TA1364
10-12-2010, 01:37 PM
pt4400
blwn_00gt
10-12-2010, 01:59 PM
i had that stall in my TA with the MS4 and i was impressed with the streetability of that stall but i never would of thought it could take a 150 hit..good run
TA1364
10-12-2010, 02:59 PM
It blows through a little. I want to put an ss4000 or an FTI converter in over the winter.
john563
10-12-2010, 03:20 PM
sam going to kk this thursday
TA1364
10-12-2010, 08:03 PM
Fill the bottle, you will have to make 1/8 mile spray runs too or you'll get kicked out.
got-a-ls1
10-15-2010, 09:38 PM
curious as to what your 1/8th times are off the spray? I just got kicked out for going 7.26 hitting the rev limiter bad on 2 and 3rd shift on a 50 shot.. Best off the 50 shot was a 7.37 @ 92and 7.39 @93 on a different day. Trapped 95mph on the 50 shot before the pressure in the bottle fell way off... no bottle heater installed and 50º temps = i made a mistake... lol
Next year when i get my FLT trans and fuel system im planning to spray whatever it takes for ~525rwhp on the stock shortblock and am wanting to hit 6.6 6.7's. Dont know if it will happen or not though.
TA1364
10-15-2010, 10:50 PM
High 7.40s, low 7.50s @92. I am making right around 525 on the bottle. If you spray through the shifts(n2o never turning off), 6.60s@102-103 should happen.
got-a-ls1
10-16-2010, 08:05 AM
nice i hope i can get there.
john563
10-16-2010, 04:08 PM
sam we should see if bill will cut us a deal to put bars in both our cars lol
blwn_00gt
10-16-2010, 08:19 PM
what nitrous kit you using? and is it a plate or nozzle?
i have a harris speed works kit but have a nos plate and its jetted for 75 and only picks up 60rwhp, so im not sure if its the kit or the plate but im not impressed with one of the two..lol
my car makes 381/371 on motor and only 437 on spray which i think that is crap..
TA1364
10-17-2010, 06:05 PM
Running a harris speed works nozzle
I'll check into it. If we are going to the track going to have to have one since they started cracking down.
john563
10-17-2010, 07:39 PM
I'll check into it. If we are going to the track going to have to have one since they started cracking down.[/QUOTE]
definately! I wanna spray at the track and not worry about getting kicked out
blwn_00gt
10-17-2010, 08:40 PM
Running a harris speed works nozzle.
what jetting you using 63/31?
