Let's say you want to add 50rwhp...
What do you add to get it?
Car has an '02 SS motor with the LS6 intake manifold and throttle body, shorty headers, dual 2.5" exhaust and Thunder Racing 224 cam.
I can't swap the cam or exhaust (this is in my Porsche 944), but I can swap heads pretty easily. Depending on how tall the intake manifold is, I may have room for an aftermarket intake manifold...
TIA!
TIA!
Since you didn't mention a budget, I'd get some AFR heads. Ask a sponsor like TSP what size would be best for your application.
I don't know how much bigger the FAST intake manifolds are compared to the LS6 and if they would fit, but you can search the classifieds for used 90/90 setups or 92/92 setups, or buy a new 102 manifold with your choice of throttle body (Vengeance racing recommends a 96mm TB I think for tuning or some reason).
A bigger MAF may help a little. Get a GM 85mm truck MAF.
Aftermarket air lid, assuming your setup has one.
The aforementioned underdrive pulley. And, a very expensive bolt-on IMO that I won't do, an electric water pump.
Well, because I already have a cam, need to stay emissions compliant and most importantly, you can't swap the cam in my car without removing the engine. I'm not going there...
So basically I'm constrained to heads, intake manifold, throttle body. I already have an air intake, space constrained, so I can't do anything else.
Not willing to do NOS, this is a road race car, so I need the power to be there for a 30 minute session...
OK, thanks for the suggestions.
Have another question, what sort of power are people seeing at the wheels with:
Shorty headers, dual 2.5" exhaust, LS6 intake manifold/throttle body, intake and a Comp Cam 224?
I dynoed 340rwhp with this. Is that about where I should be? A few folks have been telling me I should've dynoed closer to 380-390rwhp...
Got the car on the dyno again this past Friday. Got a pretty consistent 337rwhp. AFR's were good at 12.8, timing curve and advance were good, MAF was reading 9000+ grams.
All looked well, but it only made ~340rwhp.
I can make up to 370rwhp and stay in the time trial class I'm in. Should I be looking for something wrong with my motor and do a compression/leakdown test, or do I simply need to add bigger heads/cam/intake to get my +30rwhp?
Added FAST90/90 and I'm at 378rwhp now.
If he isn't sure if he can fit another intake on there the 102 definitely wouldn't be what I would try, it sits way hiher than my ls6 or 90 that I had.
I would get a set of used afr 215s and a retune.. if that doesnt get you there hen I would look into a 90 mm intake tb setup. Those afrs are going to give you a lot of midrange also which I'm sure you spend a lot of your time.
I was less than impressed with my dealings with EPS. I wanted one of their cams, wasn't told that it would take 3+ weeks to make it when I ordered it. Then when I called 10 days later to inquire where my cam was I was told the time table.
Unfortunately that didn't work for me and I wanted to cancel my order. They assured me they'd rush the cam out. 1 week later, still no cam. I call them and he know says his cam builder is out of blanks.
He then asks if it's ok to send me a Thunder Racing cam instead. I say ok, he charges me over night shipping and what turns up is a Comp Cam instead.
So all in all, a very poor experience, as well as I paid the money for an EPS $350+ dollar cam and got a Comp Cam that's quite a bit less expensive instead. No refund, no call explaining why I didn't get a Thunder Racing cam, etc, etc.
So those guys are in my dog house right now.
Another friend has pretty much the exact same setup as I do in his converted 944 and is making 389rwhp. So I don't think the exhaust is really that restricted...
