Head gaskets for 98/806's?
Hey guys, I know there is a problem with the 806 heads having a coolant leak if you don't use the right head gaskets, I have a set of fel-pro 9284 which is what was specified for the 98. It doesn't have the tab on the side like the GM ones do though. Will I have issues using these? I searched but I couldn't find much of anything about it besides the fact that it leaks with some gaskets.
LS1Tech Premium Sponsor
You do not have to run that gasket Jon listed if you switch to 243's....I would go with the 12498544's on a 243 swap if you're wanting to run a GM gasket!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The reason I chose these ones is they are slightly thinner compressed height of .041 instead of the stock which is I think .052, and I originally bought them when I was going to use a different set of heads. Its listed as the stock replacement for a 98. You're probably right though, I should just get the set I know works.
