Accessory drive compatability in a LS6
Hello LStech,
Will the engine accessories [brackets and all] from a 4th gen Fbody [98-02] bolt right on to a LS6 block? Will they still be in the original 4th gen Fbody accessory configuration? Does the LS6 block possess the right fastening points to accomplish this?
If not, are there any companies that specialize in custom accessory kits that enable the LS6 and 4th gen Fbody accessory set to work in the 4th gen Fbody?
