Wiring questions
Wiring questions
I need some advice on hooking up a few wires...
-park neutral safety switch
-pressure brake switch that unlocks the torque converter when brakes are applied.
- ses light
thanks everyone.
- ses light
thanks everyone.
The brake light switch will have to be changed to a cruise control switch, pretty much any GM car from the 70's or 80's will have the correct switch. It will have a place for two connectors to hook to it, where as your original will only have one.
The SES light just needs to be a key on powered light, with the PCM supplying ground for it.
Lol interesting. So i picked up the brake switch, i dont have a picture but it looks like my original only it has any extra set of connections so a total of four pins.
PNP switch - Normally open ground wire to PCM. Upon gear selection switch closes to signal PCM to raise idle, adjust running parameters etc......pick a place convenient to linkage, shifter setup.
TCC - torque coverter lockup. As mentioned, use a brake light switch from a car with cruise control. This contact will be +12v signal, closed until brake is depressed, breaking circuit, and remove tranny from lockup. I used 85 Monte Carlo with cruise....
SES light - connected to any keyed ignition +12V. PCM sends ground signal to light upon setting failure code.
Hope this helps.....
T,
Don't have a picture, can't see it for the rats nest of wiring..LOL. It looks like the same switch you have on your Nova now, except it has an extra set of contacts. The threaded portion will fit right in your existing bracket.
With the switch installed and pressing up against the pedal arm, one set will be closed (TCC), one set will be open (Brake lights). Upon pressing the brake, these will swap positions, breaking the circuit to the converter, and turning on brake lights. Use a fused 12 volt source for the TCC seperate from the brake lights......
T,
T,
