Rocker bolt stripped, what to do
Well, I was putting my rockers on earlier, and I got to the intake valve on the #2 cyl, and I couldn't get it torqued to 22ft-lb. It goes to 20 and starts to loosen up again, so I know probably the bottom threads are stripped. I looked down it with a flashlight and can't see any stripped threads though, so I loctite it and torqued it to 20ft-lb. Will it be an issue? I feel like it will be fine, should I try to run it or just bite the bullet and tap the hole for a bigger bolt? It seems like the bolt is chamfered on the bottom so I don't know what bolt I could possibly use.
LS1 Tech Veteran
You need to take a rocker bolt in to a parts store and buy a Helicoil kit for that size bolt (it will come in handy for other uses on the LS engine series). Then, all you will do is drill the stud hole bigger, tap the new hole, insert the helicoil according to instructions and you'll be back in business. It will be a good learning experience and it's the proper way to repair this issue.
Steve
Steve
Steve
Steve
They are new heads, which is part of why I'm pretty mad about it. I've already found 2 stripped bolt holes, the second one on the same head was the rear coolant crossover. I broke the bolt off in that one already. Still trying to decide what to do with it.
I'm a tool & die maker and you never want to hammer on a bolt to try to remove it. Most of the time the threads in the hole get chewed up, specially since the heads are aluminum. The best way to remove a broken bolt is to drill a small hole in the middle of the bolt and use a screw extractor to back it out.
The coolant plug bolt is far too small to do any of those to. I just capped the back holes and used an LS6 crossover I had for that. For the one with the broken bolt I just tapped the coolant hole and put a bolt in it with some thread sealer. I'm trying to avoid taking the heads off and ruining the gasket already.
I followed GM's procedure. #1 TDC on compression stroke for the first ones then 360* for the second set. The one that stripped had a closed valve too, I think the threads were just weak. I went and got a helicoil set last night and fixed it, started right up so far no problems.
