11.28 @ 125 Cam only
Old 10-24-2010, 05:43 PM
Demonicbird00's Avatar
Default 11.28 @ 125 Cam only
it was a street nite, so they werent blocking the groove off from the street cars.
anyway heres my best from the nite
60'- 1.699 spinning
330- 4.759
1/8- 7.286
mph- 98.18
1000- 9.472
1/4- 11.289
mph- 125.06
front shocks @ 2
rear shocks @ 8
tire pressure 16psi 26" MT DRs
leaving @ 5k
had i been in the 1.4x where i should be the numbers are there to run
10.8s @ 127/128
-brandon
next time out im trying QTPs and dial the suspension in more
car setup
full drag suspension
245/250 cam
26" DRs
viper spec trans
Spec Twin disk
3230 rw
on a happy note, it did feel good to be racing again after a year and a half
Old 10-24-2010, 08:49 PM
MYSTIC-1SC's Avatar
congrats... Once u get that sixty foot down the car will definetly be rolling out.
Old 10-24-2010, 09:26 PM
chrs1313's Avatar
congrats man glad you are back in the saddle...the 60ft will come...was this atco
Old 10-24-2010, 09:55 PM
yeah it was atco, not sure on the DA tho
Old 10-24-2010, 09:57 PM
Zmg00camaross's Avatar
Whats the specs on the cam? Raceweight? car is moving for sure.
Old 10-25-2010, 05:21 PM
245/250 .611/.615 110+1
3230 raceweight
Old 10-25-2010, 05:26 PM
chrs1313's Avatar
yeah 110 club...
Old 10-26-2010, 10:39 AM
dug
dug's Avatar
what are you shifting it at? And what size drag radials?
Old 10-26-2010, 04:59 PM
26" MT DRs, 275/50/15
Old 10-26-2010, 07:00 PM
01SS99red's Avatar
What clutch are you running.
Old 10-26-2010, 08:44 PM
all these answers are in the OP
but heres the cliff notes
car setup
245/250 cam
26" DRs
viper spec trans
Spec Twin disk
3230 rw
Old 10-27-2010, 01:27 PM
98blueSScamaro's Avatar
Sick mph and your car is charging hard up to but work on your 2-3 shift and your car will mph better in the 1/8 should go mid 6.x and i see your car going at least high 10.7's
Rob
Old 10-27-2010, 03:39 PM
thanks rob, i gotta start doing the shifting exercises in the driveway, also my mph was down 2mph on the top end, could be DA related or not having the nose taped off.
once i get the slicks on and cut my 60's to low 1.4s i should "theoreticly" (sp) see 10.60s @ 127/128ish
when you and chris come out here, maybe ill bring money w/ me incase theres an extra spot at the rental
im shooting for next tues if the weathers good
-brandon
Old 10-27-2010, 04:24 PM
demarco313's Avatar
congrats nice drivin
Old 10-27-2010, 07:27 PM
studderin's Avatar
nice times for the tires.
you run 4:10s or 4:30s?
Old 10-27-2010, 09:39 PM
RJB01camaross's Avatar
Can you break down your "full drag suspension" for us?
Old 10-28-2010, 03:22 AM
4.10s
qa1 singles front w/ 275 spring and rears
bmr ta relocation
edelbrick adj ta
wolfe drag bar
lcas
relocation brackets
sfcs
Old 10-28-2010, 10:27 AM
haha yea da is why the mph was down. get the shifting down and you should see 101mph in the 1/8 for sure.
Quick Reply: 11.28 @ 125 Cam only
