Decision on System
Originally Posted by SSactionLs1
If they are HE2's then hell yes they will hit harder. MOST of the time 2 10"s will hit harder then a single 12". More air mass moved.
I would say the Rockford 10s would hit harder but the 12" infinty will probably be cleaner. Never been a fan of either brand have installed them both, and there are alot of other options for alittle more money that are worlds better. How much money are you looking to spend on these subs? What amp do you plan to power them with?
I have either $700 or $1000, don't know yet, but I was planning on getting the millbox from Subthump so the t-top holder would still be functional. I've also got to get a new 6 1/2" sub for the sail.
Could throw 2 12" Kicker Comp VR's into a ttop box...they would work well with that airspace and can be had on ebay fairly cheap. Then compliment them with a good amp and you are set. Just something to think about.
Originally Posted by 99SeanWS6
I think I've deided upon 12W6 in the millhouse box. But what kind of amp should I get? after the othe stuff I figure I have around $200
the 12w6 should sound awesome...im agreeing w/ sidewayz tho on the Comp Vr's, i had them in my other camaro and they sounded way better than the infinity kappas i had and i believe the vr's are basically the best bang for the buck...also look into some of the elemental designs subs...
Originally Posted by 01blufrmla
I bought the SWR-1241D Alpine, and the Alpine MRP-350 amp. I got both of them online for $230. They hit so hard that I had to turn the gain almost all of the way down. I even built the box for $50. Here are some pics.
Originally Posted by SidewayzOZ
I like the box, you did a nice job with it! I was so close to going with 2 10" type R's myself
WARNING: BAD TRADER STATUS
The 12w6 says about 300-350 watts butt I run mine with the jl 500 watt amp and it sounds great. If you are using a sealed box go with 500 watts, if a ported box dont go more than 300 watts.
