LS6 383ci. For My 67' GTO
Old 10-30-2010, 07:15 PM
Jordanmd88's Avatar
Default LS6 383ci. For My 67' GTO
I figured I would post up a thread about build to maybe help others, and help me figure our any potential issues down the road..
Build List
LS6 block
TSP 383ci Stroker kit, Wiseco pistons 11.5 :1 CR
Eagle crank
Eagle rods with ARP 2000 bolts
MS4 cam
PRC valve springs TSP recommended
LS7 lifters
Ported and milled LS6 heads
Performance Products Intake Manifold
90mm Throttlebody
60 lb injectors
06' ZO6 MAF
Headman 1 7/8" long tube headers
Built 4L65E Gearbox
BMR GM A-body Tubular suspension
Summit brand Disk brakes
10 Bolt posi rear end (for now)
Started with a Used Ls6 block that needed some TLC
Had it machined to fit my pistons and a fresh hone put in it..
Pistons
Eagle crank, *yes it was balanced, 99% of eagle cranks are way out*
Some Engine Assemble pictures
Getting a Test fit FYI you have to cut the hell out of the Floor to fit a T-56 or any Automatic Gear box... I made a New trans tunnel out of 16 ga. Used "corvette glue" and pop rivets to secure it and the floor is now stronger than it was before
Going in, Gear box is a 4l65E Built for some serious power
Starting the wiring!
Fuel pump in and wired
Random, But the wheels showed up
On the ground
Plumbing the engine, I used the Summit brand Push Lock AN lines and They were awesome and very affordable
All plumed and ready to fire.
Exhaust is done
ECU and Engine fueses mounted
Front suspension
Rear End
New bumper !!!
Before cleaning up all the wires
Cleaned up and ready to go
Hood is finally on
Right now the car is running kinda, on a base tune. It's supposed to go on the Dyno sometime this week to get it running right!!!!!!
Old 10-30-2010, 07:26 PM
71ANTICARB's Avatar
That ride is sick. Looks like you plan on going round some corners.
Old 10-30-2010, 07:42 PM
Jordanmd88's Avatar
Thanks man!!!
It's not that I intend to track it, I Just wanted to be able to really drive the car..
Old 11-22-2010, 09:19 PM
reeperz28's Avatar
beautiful car every detail about it is top notch
Old 11-23-2010, 12:08 AM
brian.harmon1974's Avatar
where did you get your accessory mounts?
Old 11-23-2010, 07:45 AM
sbsrkh's Avatar
I'm looking forward to your dyno results. I'm just getting done with a similar 383 for my '72 Chevelle.
Old 11-24-2010, 09:39 AM
Topless TA's Avatar
I see a TR6 in the back ground....
any idea how hard it would be to shoehorn it into one of those
I am toying with the idea of taking on that task.
Old 11-24-2010, 10:02 AM
chuckd71's Avatar
Super nice. Is that kwik's alternator mount?
Old 11-24-2010, 10:12 AM
AZZKIKR's Avatar
Great build, turned out nice!
Old 11-24-2010, 10:45 AM
hookemdevils22's Avatar
I can't see the pics for some reason... Do you have a link to an account or anything? And I'm going to pick your brain on this stuff a bit, since I'm planning a similar swap for my '66 (though it's a 4-speed car):
-Did you use chevelle engine mounts?
-Trans x-member (not that it really matters, since I'm going T56...)?
-Accessories (again, can't see the pics)?
-Are you running A/C?
-Oil pan?
-Wheels/tires (incl. backspace, etc.)?
Anyway, I'm gonna give you a regardless. Let us know how the BMR stuff works out - I'm leaning toward an SC&C/SPC setup myself.
edit: I know why the pics aren't working - the host is blocked at work. I'll check it out at home.
Old 11-24-2010, 05:43 PM
waterhook1's Avatar
Topless Ta,
Here you go! TR6 with ls1! This is my 74 TR6.
http://www.youtube.com/watch?v=vBFySY2zh7g
Old 11-25-2010, 01:20 PM
Jordanmd88's Avatar
Thanks man
KwikPerf.com Great guys, fast shipping and they have a lot of LSX swap knowledge.
Hehehe Motor made 580 peak trq, and 570 hp.. 400 ftlbs @ 2300 RPMS
All through a built 4L65E
http://www.youtube.com/watch?v=bHsAWhR4a4E
http://www.youtube.com/watch?v=9bycH2Xa-EA&feature=related
Yea I would love too... That Tr6 had the factory 6cyl with a M44 Eaton blower on it made 250 to the wheels and it's a blast...
-Oil pan?
I used BRP mounts, Phil Brewer (the owner) is a friend of mine and Really helped me out!!! Their mounts are affordable and they bolted right up, NO Fitment issues at all..
I'm running all factory F-body ACC. Except for a Sanden compressor for my AC.
Oil pan is a CTSV pan, fits like a charm..
I forgot the wheels specs but PM me and remind me to look it up!!!
The BMR stuff is Awesome, all of it fit well and does a awesome job of handling this motor.. I have really put a beating on this car the past few weeks and even took it drifting
Originally Posted by waterhook1
Topless Ta,
Sweet swap, that thing must be scary
Old 11-25-2010, 09:23 PM
NOS327's Avatar
Looks like a walbro pump, did you just plumb it to your stock pick-up or what?
any more pics of f-body accessory fitment? I'm doing a '67 chevelle LS2 deal and would like to get power steering and a/c in there. Did you use an f-body water pump too? Any trickery to the hoses, and what radiator is that?
Thanks,
TJ
Old 11-27-2010, 06:05 PM
Jordanmd88's Avatar
Thanks,
TJ
Yea it's A walbro.. Plumed into the "stock pickup" I did cut the tank open and spot welded some baffles in it, and put some fuel cell foam in there to, to keep the fuel from sloshing around..
I'll take some more pics.. But KwikPerf.com has some great diagrams and they tell you exactly what you need..
Yes I'm using a f body water pump.. The Radiator is an Afco Racing radiator for a A-body Ls1 swap.. The lower hose is off a late model F body, and the upper hose is just a universal flex Rad. hose..
Old 11-28-2010, 09:03 AM
Jimbo1367's Avatar
Does that radiator have a trans cooler in it? If not, what did you use?
thanks,
Jim
Old 12-02-2010, 01:13 PM
Jordanmd88's Avatar
thanks,
Jim
Just an external trans cooler..
Old 12-27-2010, 07:24 PM
02SLOMARO's Avatar
Thanks man
how the hell did you get those numbers?! i have a 383, more compression, more extensive heads, fast intake and a 6-speed and i will be lucky to get 500 to the wheels. if those are correct, i am more than impressed.
Old 12-27-2010, 07:50 PM
Fahrenschnell's Avatar
Badass Ride......
Old 12-27-2010, 08:23 PM
67goatman455's Avatar
what oil pan, and engine adapters did you use?
Old 12-28-2010, 12:34 AM
CFster's Avatar
You had to cut the floor to get your trans to fit???
I didn't have that problem. Do you have your engine sitting high or far back?
Nice car BTW.
Quick Reply: LS6 383ci. For My 67' GTO
